1. Shankitage's Avatar
    I used my S7 edge in my gear VR today. After removing the phone from the accessory, I noticed that artefacts/burned pixels had appeared on the screen. They weren't there beforehand and were easily discernible in bright daylight as soon as I looked at the screen after removing it from the VR.
    It's clear from looking at the damage that it occurred when running in VR mode as the damage is mirrored exactly on the top and bottom of the screen. Does anyone have an opinion on whether or not it's worth asking Samsung to repair it given that I was using the phone as intended within a Samsung accessory and that the phone is 1 year and 1 day old?
    S7 edge screen damaged by Gear VR - any prospect of Samsung repairing it?-img-20170409-wa0004.jpg
    04-09-2017 05:54 PM
  2. bandofbrothers2112's Avatar
    Hi,
    It doesn't cost anything to pose the question to Samsung.
    I've not come across anything similar to what's happened to your phone.
    Samsung phones have a 24 Month Manufacturing Warranty.
    04-10-2017 01:41 AM
  3. bandofbrothers2112's Avatar
    Hi,
    04-10-2017 01:41 AM
  4. Shankitage's Avatar
    So, I returned the phone to my nearest Samsung Service Centre and they have had one of their 'technicians' inspect the phone. They've now called me to advise me that they believe the damage was caused by pressure being applied to the screen!
    1) The damage occurred when the phone was inside my Gear VR - the screen can't even be touched to have any pressure applied to it while it's inside the Gear VR! It was fine when it went in and damaged when it came out 10 minutes later.
    2) The damage is duplicated on the 2 halves of the screen! They seriously appear to be claiming that it's possible to achieve identical pixel damage patterns on 2 halves of the screen by applying pressure to it! It's utterly preposterous! I'd be very interested to hear an explanation for how 2 identical damage patterns could be achieved by applying pressure to the glass. Alternatively, could it possibly, perhaps, maybe be the case that the phone overheated/malfunctioned in some way while it was in the Gear VR (when it was displaying similar/almost identical images on both halves of the screen) which resulted in the damage shown in the photo above?
    I've bumped it up to their escalations department but the next stage if I don't get a satisfactory result will be to get the phone independently assessed and take them to the County (small claims) Court - something it's easy/cheap/viable for the small man to do in the UK against giant corporations. If anyone has any recommendations for someone I can pay to assess the damage, I'd be grateful to hear. Thanks!
    04-19-2017 05:27 PM
  5. bandofbrothers2112's Avatar
    It's a shame they are taking this stance but it is their right to do so I expect.
    Personally I'd look through this help link > Consumer Rights Act 2015 - Which? Consumer Rights
    And possibly seek further advice from Citizens Advice. I think they have a Contact Us section on thrir website where a person can put everything across for them to look over. Saves waiting in a waiting room.
    Yes you could go down the small claims court route but there isn't any guarantee they'll comply even if you win the case. I hope the escalations team at Samsung come up with a reasonable option for you.
    04-20-2017 12:01 AM
  1. Replies: 1
    Last Post: 04-10-2017, 03:35 AM
  2. S7 edge screen damaged by Gear VR - any prospect of Samsung repairing it?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 04-09-2017, 05:59 PM
  3. Why won't my S7 Edge restart
    Last Post: 04-09-2017, 04:59 PM
  4. my Samsung Galaxy a5 2015 never turns on
    Last Post: 04-09-2017, 03:56 PM
