1. AC Question's Avatar
    So a whole load of really annoying features were introduced with the latest Android software update, but perhaps the most irritating is that it has started beeping over the notification sounds.
    I have the bottle pop sound as my default but I get this little "BOB" noise at max volume over the top of it whenever I get a notification. Same goes for all the other app-specific notification sounds.
    I definitely haven't turned anything on, this is something that turned itself on with the update. I've searched all the settings I could think it might be under, but found nothing.
    Does anyone have any ideas?
    04-21-2017 03:11 AM
  2. Tim1954's Avatar
    Settings do "slip" or revert to default after updates at times, especially a huge one like Nougat! Just wander through your settings and set the thing up how you like. That also familiarises you with the new software...
    It's a good thing to wipe cache partition after updates, I'd do that first thing.
    pontiac005 likes this.
    04-21-2017 04:06 AM
  1. Replies: 1
    Last Post: 04-21-2017, 05:46 AM
  2. my phone says service rejected whats the problem?
    Last Post: 04-21-2017, 03:44 AM
  3. Notification bubbles
    By dov1978 in forum Samsung Galaxy S8 & S8+
    Last Post: 04-21-2017, 02:48 AM
  4. badge notification changed colour on s8
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 04-21-2017, 02:21 AM
