All voice input stops working
Erm10
277
OK Google, pressing the mic in any app, voice typing, etc.
At least 2-3 times poer week all my voice input just randomly stops working. I have to do a hard restart to re-enable it. It's really annoying!
Anyone else seen this and how can it be fixed. Thanks
Erm10
277
Just to add...the microphone button are still there for Google, Google Assistant and Gboard, etc, they just dont work unless I restart phone.
Erm10
277
In case anyone is interested, I contacted Google and I believe this problem was related to the fact that I was in the beta program for the Google app. It was difficult to find out how to get out of beta but they helped me with it. I then uninstalled the Google app and reinstalled the public version from the play store. So far so good.
French
914
27
Can you please share how you uninstalled the beta and got the regular version? I'm having issues and would like to just get on the public version as well.
LineKill
1,801
Go into applications in settings and find the Google app, tap on the 3 dots and uninstall updates.
This will take you back to the factory version and then you will need to update it through the Play Store. I have not read or remember how you installed the beta version, but if you are in the beta program for the Google app you will want to go into the Play Store first and deregister.
LineKill
1,801
I don't have the 3 dots. Since getting Nougat this phone has really been frustrating me.
Here, I will provide some screenshots, maybe that will help.
