Package Disabler Pro v9.1
doxidad
117
5
18
Yep. I spent a lot of time trying to figure out what the 2nd pkg was that needed to be downloaded. Was it something bad, and why did I have to install it differently (install from unknown source. I guess its in Play Store now). Also, when it came up after everything was installed it had 4 or 5 packages disabled but none of the ones I normally disabled. I had to load my disabled packages to get everything back to the way I had it setup. If you never saved the xml file you would have to figure out the disabled packages over again. This took way too long for just an update.
WallaceD
172
3
18
Someone posted the dev's supposed response on Reddit:
"many thanks for your report. we are fixing everything as fast as we can. Story is that samsung is constantly trying to stop package disabler to push in bloatware. They have put a block on package disabler package from disabling anything so we now have to use a supporting package called PDP engine This app is on play store https://forums.androidcentral.com/e...m.mlsplit.samsungservice&hl=en&token=tcD-jhL_ some bugs such as web view status display issues got introduced in the making of the urgent update. we have managed to fix almost all of them in version 9.3 that is now live on play store. can you please put this information on reditt"
Source: https://www.reddit.com/r/GalaxyS8/comments/6d0cdq/for_those_of_you_using_package_disabler_pro_do/
lammy8
Trusted Member
Apr 4, 2013
276
"many thanks for your report. we are fixing everything as fast as we can. Story is that samsung is constantly trying to stop package disabler to push in bloatware. They have put a block on package disabler package from disabling anything so we now have to use a supporting package called PDP engine This app is on play store https://forums.androidcentral.com/e...m.mlsplit.samsungservice&hl=en&token=tL5IWoEB some bugs such as web view status display issues got introduced in the making of the urgent update. we have managed to fix almost all of them in version 9.3 that is now live on play store. can you please put this information on reditt"
I've already spoken to the Dev and pointed out I'm on the latest firmware etc and that the app worked fine, so why change it? I couldn't even use an older version as it refused to authenticate.
magichoward
496
I was a great fan... But I also noticed I can now just disable the main offenders like Facebook and most others that I don't use from with the apps settings I think this should be just as good.. Almost any thoughts?
tsells
1,056
13
I had no problem with it (but I had previously saved a backup).
The newest update has now screwed up the app. Now I just get a screen saying that the app is activating on my device, but it never leaves that screen.
UPDATE: I found the fix for the newest update:
Uninstall PDP Engine (the app that was added on previous update). You must go to device administrator first to disable this app.
Hopefully you have a backup exported to a XML file on your phone.
Then open up Package Disabler Pro and you then reinstall the PDP Engine. Then import the XML file with the apps that are disabled. (If you don't have a backup you'll have to reset what apps are disabled.)
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Not all the firmware is the same. It may be possible the Verizon or AT&T variant broke the app and the developer fixed it so that no matter what carrier you have, it will work.
Edit: I have the PDP and the add on app, and it worked fine for me. Somewhere, one of the updates re enabled most of the bloatware on the phone. Why on Earth do I need the Yellow Pages app? (Rhetorical question...lol)
pjwk81
754
I need it as all that Gear VR and Knox stuff seriously drains battery to the point that I'd need to change phones. Package Disabler went completely mental on me last night and crashed my phone every time I tried open it, but I uninstalled both it and PDP and reinstalled them. Been fine since and it's blocking those things for me.
Mark Valentine
121
The update has caused all of my apps to reset. And when I disabled the same group of apps again, I was experiencing this problem where it wouldn't load emails when I open them, or interest browser and Bing tabs weren't loading websites. Ive been trying to see what app that I disabled caused this. But I couldn't track it down and I got tired of attempting it after like five tries. It wasn't broken and they had to update it. What was once a spectacular app is now useless for me.
cloudsofmana
