Yep. I spent a lot of time trying to figure out what the 2nd pkg was that needed to be downloaded. Was it something bad, and why did I have to install it differently (install from unknown source. I guess its in Play Store now). Also, when it came up after everything was installed it had 4 or 5 packages disabled but none of the ones I normally disabled. I had to load my disabled packages to get everything back to the way I had it setup. If you never saved the xml file you would have to figure out the disabled packages over again. This took way too long for just an update.
