Dual Sound Volume mod
ironass
5,378
887
113
One of the criticisms of the Galaxy S7 and S7 Edge by some is that the volume is too quiet.
Well, no more!
There is now a sound mod, or should I say mods, that can address this issue and even give dual sound out of BOTH speakers... a sort of surround sound.
Just finished flashing this to an S7 Edge and the sound is STONKING! (awesome). :D
There are 3 versions of the mod. 1 that just enhances the volume or the other, that offers dual sound and lastly a restore mod if you wish to revert to stock sound.
"Volume Mod Version:
- Increase incall volume
- Increase handsfree volume
- Increase multimadia playback volume
- Increase bluetooth multimedia playback volume
- Increase bluetooth incall volume
Dual Speaker Version:
- Activate dual speaker when playing media
This mod is for rooted users with a custom recovery and can be flashed on the following models...
GLOBAL & DUOS VERSIONS
- Samsung S7 930F
- Samsung S7 930FD
- Samsung S7 Edge 935F
- Samsung S7 Edge 935FD
CANADA VERSIONS
- Samsung S7 930W8
- Samsung S7 Edge 935W8
KOREAN VERSIONS
- Samsung S7 G930S
- Samsung S7 Edge G935S
Head on over to the ZuBi182 thread on xda developers forum for downloads and installation instructions...
The Sound Mod Thread by ZuBi182
This is for experienced and competent users. Please read the developement thread, carefully and thoroughly before proceeding.
WARNING: DO NOT attempt to flash this on the Qualcomm SnapDragon models.
ironass motto... "Flash in haste... repent at leisure!" ;)
Well, no more!
- Samsung S7 930F
- Samsung S7 930FD
CANADA VERSIONS
- Samsung S7 930W8
KOREAN VERSIONS
- Samsung S7 G930S
Thanks for sharing!
Version 16 of the Sound Mod is now available...
"V16
BEST VERSION SO FAR
- Fix earpiece distortion when playing music (Better treble redirection to earpiece. Create an awesome sound effect with minimum distortion. Test it yourself listening music and covering earpiece with your finger)
- Fix earpiece distortion when ringtone playback
- Fix high volume and distortion on Hangout and similar software (Testing)
- Fix headset distortion on high volume
- Improved mic sensibility on video recording (Tested and is awesome)
- Improved mic sensibility on voice recording
- Improved mic sensibility during calls on speaker mode
Am I correct that this is only for rooted S7s and will not work on the 930V?
r3dpuk3
