I saw this on instagram from a known leaker/blogger. He said the S7 would see the return of the SD Card slot but only for the S7 not the S7 Edge. Has this been common knowledge? I don't think I heard this before. I've only heard that SD card might be coming back.
I really want the Edge but might lean towards the S7 regular if it is the only version that has the SD card slot.
What do you all think? Would you go S7 over edge if this is true?
