Android System using 30% battery
ajmatson
10
hmm no problems here & even better battery life with "Package Disabler Pro" <-- No root needed.
No crank down display brightness & disable GPS nonsense etc milking the battery.
The simple fix is disable bloat such as,
Facebook Junk
Drive
Gear VR Junk
Google play Movies etc google voice Junk
Knox Junk
S Voice
Samsung+
Basically the basic stupid bloat & your device will sleep deep
Would you mind sharing screenshots of what exactly you disabled for us?
sling1
73
Some basics for those that don't know,
Google search bar widget - disable the Ok Google voice setting. So many place on home screen which is bad.
Settings / More Connection Settings / Nearby Device scanning - Off
Settings / Wifi / More / Advanced / Network Notification - Off
"Package Disabler Pro" Application - NO ROOT NEEDED!!
Disable KNOX etc with no trip device remains secure warranty in tact.
All Samsung users should have that app , sticky needed for it in every Samsung forum.
Disabled App Screenshots ,
Working apps in background & basic settings
3 Gmail accounts auto sync , Rain Alarm Pro app 2 hour sync , Weatherbug app 2 hour sync , GPS enabled , BT enabled , Hangouts enabled , Samsung pay active on home screen & lockscreen , LTE Service - VOLTE Disabled , Screen brightness 80% , Fingerprint scan enabled etc.
Just an everyday use device no major cripple going on.
Sleep trickle 1% loss every 3.5 hr
May 7, 2010
16
Thanks so much for this app. I'm trying it now and it looks like it's disabling all these apps. Hoping it works. Looks like it's root without all the effort of root!! We'll see if it translates into battery savings.
sling1
73
It will work my friend , You will be getting some good savings with knox disabled + others.
Also if lockscreen protection is in use - code or fingerprint disable the "Trusted Places" setting.
batt saving there & also thinking that setting enabled may be the Blackscreen culprit some have experienced
May 7, 2010
16
Also if lockscreen protection is in use - code or fingerprint sensor disable the "Trusted Places" setting.
I was just excited to disable KNOX!!! it said it was using 10% of my battery!!! and I couldn't disable it, i was not happy...
sling1
73
Right on my KNOX was eating 6% with some of the others at 1% - 2%.
Samsung S7 is strong device excellent hardware , without the junk bloat its a beast.
They need to change their ways go pure google as much as possible
Jun 3, 2012
22
49% of my battery is getting eaten up by Android System and Android OS. I've downloaded the package disabler pro, cleared my cache and I'm still having problems. My phone is getting so hot that it makes my hand sweat through the case while I'm on calls
Edit: I also notice that it takes forever for me to download any updates or apps even thought I have a 35+ Mbps connection.
seb1509
Active member
Jul 28, 2013
30
Hey,
Quick question do you have the US version with SD820 or the exynos version? Also... does android system show up draining 20%+ on your battery stats? I have the s7 I am getting very decent battery life but the android os is draining 20%+ off my battery. I did most of your recommendations but I have not disabled knox. I am trying to figure out if Know and Gear VR are the problem or not!
If anyone else reads this and does not have the android system battery drain problem please reply to this.
I have been doing research and reading different forums trying to figure out what is happening. And it seems like the exynos does not have the android os problem.
Jason Stroud1
208
I've noticed the last part about this downloads as well
sling1
73
I would hard reset run stock for a day , If the hot makes your hand sweat returns it may be time for replacement.
If it runs cool like should install Package disabler & disable the basics no deep system packets
victoryrules8
358
Perhaps this has something to do with the doze features if marshmallow or the app optimization features. Just a thought?
drone3
630
BEFORE (With AOD ON, WIFI ON)
AFTER (With AOD Off, Wifi Off)
3.5% battery drop per hour Vs. 0.37% drop per hour
turning aod & wifi off definitely "fixed" the problem.
I experiment try twice more with just aod or just wifi off to see which one is the real cause..
Guys just letting you know I have been through all this with the S6. WiFi was the culprit for the S6, and I just chose the setting 'WiFi off with screen is off unless plugged in' that fixed most my issues.
A few more annoying things I had to do was turn location, Bluetooth, nfc all off, until I needed them.
dreaming of electric sheep
sling1
73
Updated screen shots 22 1/2 hours 80% battery remaining , SOT little over an hour with Android System info
allensize04
Active member
Aug 6, 2010
25
Somebody on a another topic said to turn off global and set your mobile network to CDMA I am assuming GSM if your carrier uses it. I haven't tried it yet.
unclerobmac
3
I have the HTC One M8. Just updated to Marshmallow. I have used two battery apps Deep Sleep Battery Saver Pro and recently switched to Greenify. With M having the new DOZE feature, Greenify has in settings Agressive Doze. So far really works great. The BIG users are wifi, bluetooth and app updates/syncing. Most notorious is your push email app and Facebook, they use huge amounts of battery to keep updated. Deep Sleep will turn off things and only check sync a set amount thats adjustable. REALLY reduced battery drain in Android L. With the switch to Android M, Greenify and new built in DOZE has been even better.
drone3
630
Unfortunately, these are the steps you need to take for brilliant battery life.
t11rmh
637
Here's my battery usage. Seems OK to me. Others may disagree.
OK didn't load up the other pictures. Ignore.
Posted via the Android Central App on a kicking Samsung Galaxy S7
Jason Stroud1
208
Damn. That sucks.
Mine only drops about 1% an hour over night.
Overall I've been pretty happy with my battery life.
Just giving an update, after disabling wifi during sleep, a few more bloat apps, and always on display i only lost 4% battery last night during sleep. Wayyy better than the 16% I was getting before the tweaks.
mumble, grumble. :s That's disappointing.
I suspect that you have a wakelock somewhere, because your WiFi is on 100% of the time on the GSAM shot and the stats show that the device is active for 3 hr 12 minutes out of 5 hr 47 minutes but the screen was only on for 1 hr 12 minutes. So that two hours could perhaps account for streaming pandora with the screen off, but if that's not the case then that's where I'm suspecting a wakelock.
Your stats are trending for 3 hours SOT out of 14 hours total usage compared to another user who is trending for 5 hours of SOT over a 24 hour period - so there's definitely room for improvement, we just can't do an apples to apples and say that 5 hours over 24 hours is the goal, because it might be too aggressive or not aggressive enough.
