Galaxy S7 cell standby battery drain
A
AC Question
I've seen this issue with the S6, but the differences between the 2 phones doesn't allow for the same tweaks. I thought I had good battery life for the first month of owning the S7, but lately, it has taken a hit. I was at a 20% drain rate after 4 hours, and now it takes about 2 hours. Cell standby is using 33% of my battery, without much other usage as I work.
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,384
249
63
Welcome. I'll request that this be moved to the Samsung Galaxy S7 forum, where you'll be more likely to get advice.
peanut140
Were you able to get this figured out? I am having the same issue. Cell Standby took up 27% of my battery today, it's only 5:00 and my battery is at 15%.
Time without signal: 0%
Total connection time: 3h 43m
Computer power usage: 1041 mAh
popkurn611
1,368
You have to disable advanced calling, power off phone, hold down power + home button + volume up until the recovery boots and wipe the cache. Restart phone and then re-enable advanced calling. Did the trick for me
RandyABox
Delete all data for Google Play Services and it'll stop this for a week or so. When it hits a certain amt of memory used, it'll immediately start the battery drain again and you must repeat the process.
