1. GS5TR's Avatar
    Do you guys also have some problems with battery draining after installing nougat 7? I have draining while using and also when I do nothing..? When I go to battery stats, its only showing 1 to 3% of running apps, like android system, screen, mobile standby... so that's nothing..? Someone know what it can be?
    03-19-2017 03:14 PM
  2. Premium1's Avatar
    Try doing a factory reset? Sometimes that helps after updates.
    Paul627g likes this.
    03-19-2017 04:24 PM
  3. meattray's Avatar
    I've only noticed an increase in battery life. Seems strange. When did you update?
    03-19-2017 07:33 PM
  4. Joe1776's Avatar
    So the first day after Nougat I was thrilled. It was like my phone battery was back to day 1. It lasted all day with heavy usage. Every day since my battery has barely lasted 8 hours.
    It is absolutely insane, I can't explain it.
    Also my fast charge won't work. And yes before anyone asks, I've tried using both my and my wife S7 OEM fast chargers (both work for her, she still hasn't upgraded) as well as my Ankur cord which was a speed demon for charging previously. Nada.
    Everything is slower, I honestly couldn't be more unhappy had I bought an Apple.
    GS5TR likes this.
    03-19-2017 08:31 PM
  5. Paul627g's Avatar
    I would consider a factory reset as much as we all hate to do it. But it maybe the exact thing you need to fix the problems.
    GS5TR likes this.
    03-20-2017 12:38 AM
  6. Biggmac419's Avatar
    Yeah same here. It's been amazing since updating.
    GS5TR likes this.
    03-20-2017 01:17 AM
  7. GS5TR's Avatar
    Uhm.. think like 3 weeks ago...
    03-20-2017 03:50 PM
  8. meattray's Avatar
    Yikes! Have you installed GSAM or something to get a better look at your battery stats? Might help give a little more insight?
    03-20-2017 04:15 PM
  9. Coffeeguy24's Avatar
    POSSIBLE FIX!
    My wife and I have identical phones, bought from same carrier few days apart, 85% apps are the same, and after update her phone is doing great, but mine is eating battery like mad: almost 2% an hour sitting idle, battery could not last 10 hours on pretty normal use. Restarted randomly a few times. Before upgrade my phone lasted 24 hours easily.
    Tried everything I could find: wipe cache, reset app preferences, set a high performance mode without optimization, even did a factory reset. Nothing.
    Flashed official firmware from Sammobile, but only the AP part. I know that back in my Note3 days, the AP was only thing I needed. What a mistake. After that I lost vibration and got some double tabs in “settings”. The phone did not lag, but it wasnt doing good either, and the battery was horrible. Lost 15 percent overnight on idle.
    I then reverted to official 6.0.1., and after that I flashed 7.0 again, but this time I flashed everything that was in the archive from Sammobile:the BC, AP, CSC and something else, cannot remember what it was .
    What a difference!
    The phone went back to normal, the OS is smooth, and the best part: lost only 4 percent of battery overnight!
    So, looks like this is the way to go. If you are unwilling to do the full reset, things have changed since older Samsung phones.
    How I did it:
    Thru Samsung cloud. You can backup everything you want: I moved my pictures and any other large files to SD card, and let the phone backup. It will backup everything except your app data: homescreen layout, alarms, contacts, calendar (if you already do not have it on Google).
    The whole process lasted no more than an hour from start to finish with backup, flashing and restoring. Could not recommend more!
    75% battery from 3PM yesterday lasted until 10 AM this morning.
    So far so good.
    Norg likes this.
    03-21-2017 07:32 AM
  10. Joe1776's Avatar
    I have to wonder what's going on internally... after a few days of no fast charging, it just started working again yesterday. Maybe it took 101 toggles of the fast charging button?
    Battery life is still very hit or miss, mostly missing.
    03-21-2017 10:54 AM
  11. Coffeeguy24's Avatar
    Here is a quick update from me.
    Light use yesterday, 2 mail accounts on sync, wifi and gps on, screen on auto, high performance mode with no offset on display brightness. About 1.5 hour of screen on time.
    It seems that, when used, it will drain battery faster than on marshmallow. During writing this post 3%battery gone :-)
    Attached Thumbnails Battery drain after nougat 7-screenshot_20170322-080220.jpg
    03-22-2017 02:10 AM
  12. Norg's Avatar
    POSSIBLE FIX!
    What a difference!
    How I did it:
    So far so good.
    How is it performing now?
    03-25-2017 11:02 PM
  1. Poll: LG V30 removable battery or not?
    By jeffhuypham in forum Rumored Devices Lounge
    Last Post: 05-03-2017, 08:47 PM
  2. Battery issue
    By amyf27 in forum Samsung Galaxy Note 5
    Last Post: 03-19-2017, 12:52 PM
  3. grand prime plus battery drain issue
    By Kingjd123 in forum Samsung Galaxy Grand
    Last Post: 03-19-2017, 12:21 PM
  4. Replies: 1
    Last Post: 03-19-2017, 12:16 PM
  5. Samsung battery drain issue
    By Kingjd123 in forum Ask a Question
    Last Post: 03-19-2017, 11:43 AM
