Samsung Galaxy S8 Active battery size prediction?
Matty
Q&A Team
Mar 15, 2014
1,596
So, i recently heard that Samsung is gearing up to release their 'Active' version of the Galaxy S8. If we look at the previous versions of the Galaxy Active range, it comes with the same specs except with a monster battery :D
S7 Active - 4000 mAh
S6 Active - 3500 mAh
S5 Active - 2800 mAh
So what do you think we will get this year? The same size or bigger? is 4,500mAh asking to much? :D
Since the S7 & S8 batteries are the same size, I would believe the S8 Active will have the same 4000 mAh type of battery as the S7 Active.
slackingfred
