Question please regarding how to transfer all data/info from current S7 Edge to the incoming new S8+:
Assuming you have a current Samsung phone (I have the S7 Edge), how do you transfer all your information from your old phone to your S8+? in the past, i've always used the Samsung Smart Switch, which uses NFC to transfer the data over. it works but i'd say only around 90% or so of the stuff gets transferred over. there's always around 10% that's somehow, not done.
I also read that there is some NEW USB-type adapter included in the box (I'm not talking about the USB-C adapter) and it is supposed to be used as an alternate method of transferring from your old Samsung to your S8+.
is that true please? what is the NEW WIRED method or the NFC previous method? are you using Smart Switch even if you're using the new wired method?
thank you.
thank you.
