I'm not changing the launcher just yet. So far today the phone has been very smooth I have been using It for about the past five hours
I liked it quite a bit. I usually use Nova, but so far the only thing I really miss about it is the greater customization of the persistent app tray at the bottom. Samsung's skin only allows 5 icons, plus folders, which may actually be a Google limitation, as I do not know. But I do miss that part of Nova Launcher, enough that it will probably force me to install and use Nova Prime again.
Still, the Samsung TouchWiz is actually pretty nice so far
Is the Samsung Experience worth sticking with as opposed to any other launcher?
I just setup nova yesterday. So far adjusted the icon sizes and will probably get custom icons later today.So has anyone put Nova on there phone yet? I never used it but have not got my phone yet so do you still like stock? or have you went to Nova
I agree it is much better than my seven edge was i've already got that phone packed up to returnIt's a lot better than what I ha d on my S7. I'll likely be keeping it.
Does TouchWiz have gestures?. With that taller screen I know I'm going to want the swipe down to open notification bar. I'm not holding my breath that using the FPS is going to be a easy way to do it.
