1. ReeceF11's Avatar
    Hi everyone, so I got my s8+ today and was wondering does the 2016 Gear VR work with the S8+?
    04-20-2017 03:21 PM
  2. Mark Molitor's Avatar
    I think so. Not 100% sure but I would hope they wouldn't promo it with the 8+if it didn't work. I registered for my vr today and it said 6 to 8 weeks!
    04-20-2017 03:26 PM
  3. ReeceF11's Avatar
    I've been trying for about an hour now and it still will not fit, If anyone else could give me some help as well would be great.
    04-20-2017 03:28 PM
  4. nunyabiziz's Avatar
    Dont try anymore unless you want to damage your phone and Gear VR. S8 uses USB type C and previous phones uses micro USB
    04-20-2017 03:36 PM
  5. me23brown's Avatar
    It won't work with the plus definitely too tall. I was disappointed with it myself.
    04-20-2017 03:39 PM
  6. ReeceF11's Avatar
    That explains it I'll take it back because this is the one that store gave me with the phone. Should change it for the 2017 model.
    04-20-2017 03:40 PM
  7. nunyabiziz's Avatar
    Yes, 2017 version works on all phones.
    04-20-2017 03:42 PM
  8. Mark Molitor's Avatar
    Just realized you said 2016.... derp.
    04-21-2017 08:08 AM
  9. bassplayrguy's Avatar
    There is an adapter in the box with the 2016 VR.
    04-21-2017 09:38 AM
  10. RoyTxxx's Avatar
    No there isn't - at least there was not in mine which I got when the 2016 was first shipped with the S7.
    And I think that the S8 USB type B to USB type C adapter will make the S8 too big to fit into the Gear VR 2016 (a dangerously tight squeeze at best for the S8+, I'll try my S8 later today and update - UPDATE - No: Not a chance of it fitting)
    The New Gear VR 2017 has a changeable adapter which can be switched from USB Type C to USB Type B, so it is backwardly compatible. Apparently this is the same as the Gear VR that was shipped for the Ill fate Note 7, so I am going to refer to this as the Gear VR 2017 for the sake of brevity.
    04-24-2017 05:15 AM
  11. zipro's Avatar
    The 2016 version - at least the one that came with the Note 7 - also has a changeable adapter (USB Type C and USB Type B), but even with the adapter the phone won't fit. I can't even get it into the adapter for some reason.
    04-24-2017 05:57 AM
  12. papabutter's Avatar
    I just used my s8+ in the 2016 vr it was a really tight squeeze but it works! As long as you have the USB C adapter it came with you should be good.
    04-24-2017 06:14 AM
  13. RoyTxxx's Avatar
    Is this the USB C adapter that the S8+ came with, or the one that the Note 7 2016 Gear VR came with?
    Ruikee likes this.
    04-24-2017 06:31 AM
  14. Ruikee's Avatar
    Yes, anyone got a picture of the adapter that will allow the S8 to work with the Gear VR that came with the S7?
    04-24-2017 11:42 AM
  15. hdhuntr's Avatar
    Picture is irrelevant. It is too tall with the adapter on it.
    04-24-2017 12:18 PM
  16. TylerLV76's Avatar
    Theres 3 versions of gear VR.
    2015 - White, microsd only http://forums.androidcentral.com/e?l...token=MXoRiuNu
    2016 - Black Micro SD and USB-C adapter http://forums.androidcentral.com/e?l...token=rMWqh3Ak
    2017 - Black Micro SD and USB-C adapter. Same as 16 but comes with the controller http://forums.androidcentral.com/e?l...token=uuPGJMu5
    If you are trying the white one it will not work. Only the 2016 model (Black) and up will work.
    Ruikee and Zomby2D like this.
    04-24-2017 12:23 PM
  17. bassplayrguy's Avatar
    Mine works just fine
    04-24-2017 12:53 PM
  18. bassplayrguy's Avatar
    I registered on shop last week and still no response other than saying approved.
    04-24-2017 12:53 PM
  19. bassplayrguy's Avatar
    I can post one after work
    Ruikee likes this.
    04-24-2017 12:54 PM
  20. whaddupdoe's Avatar
    I have a 2016 Gear Vr that came with the USB C adapter in the box. I had no success with my s8plus. It was too tall but if you guys are saying you got it to fit then ill try it again.
    04-24-2017 12:57 PM
  21. TylerLV76's Avatar
    Did you move the position on the headset to position a?
    whaddupdoe likes this.
    04-24-2017 01:01 PM
  22. RoyTxxx's Avatar
    Can anyone point me at the web page where I can buy the 2017 Gear VR (With controller) in the UK (SM-R324)?
    There seems to be a couple of retailers selling at premium prices, but nothing from Samsung:
    Here is one at £129.99 which seems a little steep, especially as it is almost identical to the SM-R323 (except with Controller) which retails at less than half this price.
    Official Samsung Galaxy Gear VR Headset with Motion Controller
    04-26-2017 06:26 AM
  23. LordGeek's Avatar
    I also have the 2016 Gear VR .. Samsung Galaxy S8+ .. definitely a tight fit, however, I played with it for a couple hours .. installed, uninstalled, reinstalled, uninstalled .. for the life of me, I can not get any sound out of my phone when it's connected to the Gear VR !!
    Anyone run into that issue ?
    05-01-2017 07:48 AM
  1. S8+ Gmail Sync Issue! Doesn't sync nor give notifications on a timely basis
    By Dualmonitors in forum Samsung Galaxy S8 & S8+
    Last Post: 05-20-2017, 02:03 PM
  2. Light bleed on my midnight black s8 plus
    By Dhawk1202 in forum Samsung Galaxy S8 & S8+
    Last Post: 05-11-2017, 09:06 AM
  3. Can I use a Pixel charger with the S8?
    By csiguy1 in forum Samsung Galaxy S8 & S8+
    Last Post: 04-20-2017, 02:54 PM
  4. oneplus one + jabra rox + gear s3
    By st_this in forum Ask Jerry!
    Last Post: 04-20-2017, 02:25 PM
  5. S8 and S8+ screens!
    By VDub2174 in forum Samsung Galaxy S8 & S8+
    Last Post: 04-20-2017, 01:56 PM
