The Galaxy S8 has a frustrating Bluetooth problem, but a fix is on the way.
I hope this addresses Gear S3 connections as well, I don't usually have a problem with it except for two scenarios... If I walk away from my my S8+ while still connected to the same wifi and after disconnecting my S8+ from my Silverado using Android Auto.
Personally, I have had no BT problems at all interfacing with my aftermarket Pioneer unit.
Odd it seems to be so hit and miss.
Mav. :cool:
Always seems to happen with mass produced devices. Pixel and One Plus had early problems that were hit and miss and later fixed. S7 had a overheating issue that was hit and miss.
Mav. :cool:
Me too as well. My S8's BT connection has been fine for music at the gym, talking on my headphones for a call, etc. I'm sorry to hear that there are people with this issue though. Hopefully Samsung will address those with the issue via s/w update ASAP. Maybe the issue is with the S8+ not the smaller S8?
Anyone searching and have this issue... did you try this?
Quoted from another thread
I was having problems with Bluetooth pairing and connection stability until I turned off nearby device scanning. My guess was the scanning was interrupting existing connections.
VascoPJ1377
