Will the length of my S9+ charging cable affect it's fast charging time/rate? I'd like to buy a couple 6ft cables for it and our Pixel 2 XL.
Thanks
Thanks
If the charging wires in the cable are thick enough, it can be miles long, but if you buy a cheap 6 foot cable, the wires are probably too thin, and the charging time will go up. And copper is expensive, so stay away from 99 cent 6 foot cables.
That did make me laugh - more than just 2 smiley's worth.And copper is expensive, so stay away from 99 cent 6 foot cables.
Yep. I spend at least $1.99 on them
It doesn't actually say what gauge wire the power leads are, but Anker is generally good quality (not just their cables - all their products).Wow, these Anker USB C 3.0 charging cables are twice as thick as a "normal" charging cable. That's a good thing, right?
(https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU6230989
USB C Charger, Anker PowerLine USB C to USB 3.0 Cable (6ft) with 56k Ohm Pull-up Resistor for Samsung Galaxy Note 8, S8, S8+, S9, MacBook, Sony XZ, LG V20 G5 G6, HTC 10 and More)
As good? Of course. Any charger will. As fast? They're both listed as 2 Amp adaptive fast chargers, so it should.But, is this going to be a problem? I can't find the power brick that came with my S9+ Whaaat??? There's absolutely NO reason for it to be missing from behind my bed No grandkids have been here to use it. DH has his own. It just sprouted legs and walked outta here! I have the fast charging brick from my S7. Will that work just as good? As fast?
The Anker QC power bricks are good quality, I got a few of those as well. Definitely as fast as the Samsung one. And if you get a device that supports QC3 then at least you'll have an adequate power brick for it.I like Anker
I found the lost fast power brick. SOMEone took it into the spare bedroom when she took a nap with the dog the other day. SOMEone shall remain nameless! I compared all the specs on the S7 and the S9+ wall charger and they're exactly the same.
