Hi all, this is my first post on Android Central. I need some help regarding a problem that has just cropped up on my SGS3-I9300. I'm using this phone on T-Mobile USA and have had absolutely no issues at all, until today. Earlier, the phone prompted me to perform a software update. After the update, the 'roaming' icon is perpetually on. This happens even though I'm at home, at a location where I know for sure that I am not 'roaming'.
I've powered the phone off and on numerous times, and also done a factory reset, to no avail. I've also spent the better part of the last several hours searching various forums and it seems like others have had similar problems, unfortunately I haven't found one that has given a solution. The phone is on Android 4.0.4 / I9300XXLFB.
I'm running out of ideas. Why is my phone doing this? I really don't want to have to check on 'data roaming' just to get rid of the warning triangle. That's really sweeping the problem under the rug and not addressing its root cause. Please help... Any help would be greatly appreciated...
