Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By cyanogen-man
    DSDCreations's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Jelly Bean 4.1.2, CM 10
    Unhappy Help, Cyanogenmod 9 stuck on boot screen....
    Help me fast please!!!
    So i rooted my SGS3 with clockwork, but i installed Cyanogen 9 instead of 10 (I'm running Android 4.1.1) and now when i try to boot it it just indefinitely plays the boot animation. And when I try to debug it or download it again from odin, nothing happens.
    Please help me quickly and thanks in advance.
  2. #2
    cyanogen-man's Avatar
    Posts
    Global Posts
    1,049 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ice cold sandwich aokp
    Default Re: Help, Cyanogenmod 9 stuck on boot screen....
    Did you do a Android backup? I hope you did!! Now try this. Go to advanced delete the dalvic cache.
    Reboot see what happens
    INSPIRE AOKP ICE COLD SANDWICH ROM
    funkylogik likes this.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I can't turn the phone on, can't acces the recovery menu, just odin mode and i installed 9 instead of 10 i think that messed things up.... Any other suggestions?
  4. #4
    tall_geek's Avatar
    Posts
    Global Posts
    57 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM10
    Have you tried installing the stock rom through Odin? As if you where doing an unroot that may get you back to a working base.
    Sent from my GT-I9300 using Android Central Forums
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    And where do I get it from?
  6. #6
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    Quote Originally Posted by DSDCreations View Post
    Do you defo have CW installed? And tell us you DID do a backup :thumbup:
    Unbranded Official TW s3.Paisley,Slotland, Western Europe :beer:
  7. #7
    Posts
    Global Posts
    1,049 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Yea you need to do a Android backup!!! That's the fail safe from the flashing process. Also with the gs3 having the same specs, and multiple carrier with 2 verients. One us lte with the s4, and the international using the exinose quad core. You need to match the roms by the model #. Not all s3 rooms are compatible you can and will easily brick your device. Thrue flashing the wrong rom type!!!!. Fallow instructions to the letter, if you don't you can brick it!! Now the good news is if you can get to download mode your not hard bricked So go to www.xda-developers.com find the factory image ruu. Flash it you will loose root and everything else. But you will have your phone! Reroot and run the process all over again. And idk about twrp. I use clock work mod which is in the play store under from manager. Once you get this settled. Pm me and I will see if I can help you
  8. #8
    Posts
    Global Posts
    1,049 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    OK did some digging your on the sprint net work?? If so I can see if I can get someone a lot better acquainted with this than i
  9. #9
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    Initials S A ?
    Unbranded international s3 with Official JB. Paisley, Slotland, Western Europe :beer:
  10. #10
    icebricker's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had the same problem when flashing CM9.
    The solution I stumbled into is to flash CF-Insecure-SGS3_XX_NEE_ALE8-v1.2.tar; then enter recovery mode, do 1) clear user data/factory reset 2) clear cache 3) Advanced--> clear the dalvic cache. After this recycle into download mode, and flash CM9 again.
    I'm super noob myself, hope this helps.
  11. #11
    Mladen Coko's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    good stuff bro!!!
  12. #12
    2nipun's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi .. hope you can help me with installing Cyanamodgen on my Motorola Xoom Wingray. I know this is not for Xoom, but my problem is same. I get stuck at CM logo indefinitely .
    I followed the following procedure :
    Started from Stock 3.0 > Fastboot to Unlock > Rooted > Installed ROM Manager from Store > Downloaded the CM10 ROM and installed from it directly > Installs good > Reboots and gets past Motorola Sign > Stuck at CM Logo with the animation going on and on. > After a Bit restarts and gets stuck at same place, so a loop of this goes on.
    I can access recovery, so went back to stock and followed same procedure to Install CM9.0 instead, but same problem.
    Can you please help.
    I used the following links to learn about it :
    For Root :
    Xoom WiFi (MZ604) Root!! - xda-developers
    For CM
    Motorola Xoom (Wi-Fi): Full Update Guide - CyanogenMod Wiki
  13. #13
    Mike Volt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Dude, you are not alone. I am also having the same problem but worse! I can't turn it into recovery mode because it started up again........ And its stuck on the boot screen.
  1. HELP Xoom stuck on boot screen
    By luvable31 in forum Motorola Xoom
    Last Post: 06-07-2013, 05:52 PM
  2. Please help. Phone stuck on boot screen :(
    By aarrodri in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 07-09-2012, 10:49 PM
  3. HELP Messed up DX2, stuck on boot screen!!!
    By wcsoccerboy828 in forum Motorola Droid X2 Rooting, ROMs, and Hacks
    Last Post: 01-22-2012, 06:25 PM
  4. HELP Xoom stuck on boot screen
    By luvable31 in forum Motorola Xoom 2
    Last Post: 01-22-2012, 04:33 PM
  5. cm7mod stuck on boot screen, help plz
    By sk8dayfuknight in forum Virgin Mobile Optimus V
    Last Post: 04-18-2011, 06:03 PM
