06-03-2014 03:20 AM
267 1234 ...
tools
  1. Hassan K. Malik's Avatar
    Guys make sure that u people have modem/baseband XXELLA....
    Sent from my GT-I9300 (Hassan Khalid Malik) using Android Central Forums
    01-27-2013 03:22 PM
  2. johnnytwebb's Avatar
    Same problems as mentioned in this thread; baseband version I9300DXELK1
    01-27-2013 10:44 PM
  3. l3ambin0's Avatar
    I also think it's a WiFi Problem!. May be a driver or something?
    01-28-2013 09:30 AM
  4. Sl0th's Avatar
    i have noticed mine is freezing again still no as much as previous times , still having to reboot phone each time it does.
    As waiting for it to fix takes too long or never does unfreeze
    01-28-2013 02:29 PM
  5. Jamie Gotheridge's Avatar
    So you did nothing?!
    I did a factory reset earlier today and its froze 4 times in around 6 hours, apposed to 30 times!
    I really don't fancy waiting 2 weeks for it to be warranty, when theres a fix
    01-28-2013 04:55 PM
  6. Hassan Skaik's Avatar
    I have the same problem, i wipe all data and install may roms "custom and stock" , but the same problem.
    Any idea?
    01-28-2013 05:04 PM
  7. Sam Sam1's Avatar
    me too
    since update to 4.1.1 started screen freeze ....
    and exhausted.... feel very disappointed to samsung
    I want to ask is jelly bean own problem ?? or samsung fireware problem ??
    Is Samsung know that ?????
    feel disappointed to samsung
    coz i am using samsung smarttv , also have problem with the share all function . also no solution from official.
    01-28-2013 11:25 PM
  8. johnnytwebb's Avatar
    As oddly as it began the freezing issue has now disappeared for more than 24 hours now (knock on wood).
    I did absolutely nothing to the phone.
    The other night it froze but I didnt turn it off just let it be and plugged it in to charge. And voila the next day it was performing as if nothing happened.
    To those thinking of sending it back Id recommend waiting a bit and seeing if it sorts itself out.
    01-29-2013 02:38 AM
  9. tricia.dawn.williams's Avatar
    I think I agree with you. Mine has been ok for the past four days. I'm still not happy about the situation but at least it's not giving me problems.
    I don't want to send my phone anywhere because whever I did it, it always came back worse.
    Sent from my GT-I9300 using Android Central Forums
    01-29-2013 03:40 AM
  10. Breakwhore's Avatar
    So they couldn't replicate the issue. I had a feeling that might happen.
    Does this kinda thing look familiar to anyone?
    https://docs.google.com/file/d/0BxTH...BwQUE3VGs/edit
    01-29-2013 03:48 AM
  11. Sl0th's Avatar
    mine seems to come and go.
    the video you posted kind of seems what happens like it freezes and stuff is still running in the background it seems.
    01-29-2013 03:06 PM
  12. betty_boop245's Avatar
    Mine is still freezing, it doesn't seem to be as frequent, once a day for the last two days as opposed to 3 times a day before that, but there is no pattern to it. Im going to see how it goes the next few days, and if it doesnt stop, im going to give it to Samsung for them to fix it, as that seems to be what they are advising people to do.
    01-29-2013 03:13 PM
  13. Hassan Skaik's Avatar
    I install WanamLite V5.6 and install siyah kernel with it, with full wipe, it's now 24 hours without any freeze...
    WanamLite MA2 V5.6 Android 4.1.2 Aroma Installer & Smooth & Rock Stable
    [KERNEL][18JAN][JB][DualBoot] SiyahKernel S3 v1.8.9 - xda-developers
    01-30-2013 02:03 AM
  14. SSGalili's Avatar
    so basically there is no fix for this problem as of yet?
    it randomly fixed it self for a few users...
    can i assume that in couple of days it will sort it self for me? or shall i try to do something??
    untill now i realized that with wifi off it happens less often.
    also if i wait the freezing time about 20-30 minutes it turns its self back on.
    this began for me 2 days ago.
    02-01-2013 08:38 AM
  15. fredsie's Avatar
    I know this may sound far-fetched, but are any of you using a gel-type protective cover on your phone? My phone was playing up in the way described by many of you, and scrapping the rubbery cover I had bought for it back in April fixed the problem immediately.
    Don't ask me how this works. I can only guess that the cover had shrunk and started applying pressure to the phone, the screen or the buttons. Who knows?
    UPDATE: Disregard the above. After 2 days, the phone is freezing again. So the problem is not the cover. Although if it's down to a broken connection or similar, fitting a tight cover may set it off I suppose.
    02-01-2013 10:49 AM
  16. jakeinator21's Avatar
    I have the same problem. Usually the phone would freeze after I initiated some action for an app. The screen would freeze on the app, and the hard buttons would be unresponsive. The notification bar would be active still, so i could pull it down, but once I let it go after pulling it down, it wouldn't go back up. I could push the power button and the screen would go black, but when I pushed it again, it would display exactly the same screen. I was on Wicked rom at the time, thought it might be a rom issue, but it wasn't that bad so I just let it continue. After a week or so it started to get really bad. One day it stared freezing almost every hour, so I decided to flash back to stock. After going back to stock and doing a full wipe, including a format of the sd card, it seemed to do fine, but trying to install a zip via cwm recovery, it froze again. Unexpected to see it happening in recovery, as I assumed it was a software issue. Phone was fine for two days without freezing while it was running. On the third day, today, it froze again in the exact same way. So that's where I'm at now. Thinking I'll get it replaced.
    02-01-2013 10:54 AM
  17. betty_boop245's Avatar
    Well as an update, I got so fed up with the freezing issue, that I took it to my local Samsung service centre. As soon as I told them what the issue was, they said theyd had quite a few people in with the same issue. They wiped my phone and re-flashed (? sorry not very techy, this is what they said!) the software, and its been fine for the last 3 days, so freezing, no lagging and no reboots.
    02-02-2013 08:27 AM
  18. Jordan Burnham's Avatar
    I have been having a similar problem as you all.
    Mine freezes, but unlike the video above everything freezes. It's like someone has put a sticker over the screen; even the notifications bar gets icons stuck halfway down.
    I have tried to factory reset it and it came back almost instantly, then I did the switch off, volume up button, home button and power button to reset it that way and clear some cache... So far, about half an hour, and it's going good. Probably not for long.
    Mine was unlocked by code, no root or anything like that. Originally on Three UK, but now used on giffgaff (O2-UK).
    Anyone know if Three will accept a repair if it isn't being used on their network?
    02-03-2013 05:31 AM
  19. maschenazi's Avatar
    Have exactly the same problem. It all started about a week or so ago when I installed ARHD 20.0. Since then I tried ARHD 21.0 which is based on I9300XXEMA2, but I had the same freezes. I don't think is anything to do with WiFi, because I was visiting BETT show in London on Thursday and I had probably the worst day with more than 30 freezes and I had not been connected to any WiFi. Friday I flashed stock ROM I9300XXELLA UK unbranded and reseted my flash counter with triangleaway (see xda forums if interested) so I can send it to Samsung for repairs. I had freezes after flashing stock, just not as many. But without doing anything else to the phone it all stopped and since Friday afternoon I had no more freezes (40 hours so far). I will have to cancel the service request now...
    02-03-2013 05:59 AM
  20. SSGalili's Avatar
    maschenazi
    For how long did you have the freezing issue?
    Before it became better?
    02-03-2013 08:58 AM
  21. tricia.dawn.williams's Avatar
    Mine stopped on its own after 3 days of continuous freezing. So far it's been behacing for over a week and I haven't done anything to it because I was too scared to mess with the phone.
    02-03-2013 09:13 AM
  22. maschenazi's Avatar
    It all started about 10 days ago. It was bad for 2 days. I suspected it had something to do with the microSD card, so I removed it and the phone behaved ok-ish for 2 days then it started to freeze again for another couple of days. I tried all sorts, like different kernels, different roms factory resets, etc. Never had more than 2 dsys quiet
    02-03-2013 11:19 AM
  23. Jamie Gotheridge's Avatar
    Still doing it only a couple of times a day
    02-03-2013 05:17 PM
  24. FDisk80's Avatar
    Look here guys. xda-developers - View Single Post - Galaxy S 3 keeps freezing every 5 mins (50+ freezes a day)
    After doing this I'm already 4 days without any freezes.
    maschenazi likes this.
    02-04-2013 02:17 AM
  25. Pranav Nigam's Avatar
    What if I don't want to root my device..!
    Anyways i was having the same issue since i updated it to 4.1.2. I tried things like formatting/factory reset etc but like everyone else it didn't worked out well.. Earlier the issue was for 5-6 times a day but one night it was freezing every time i switch it on within 5 mins interval.
    So i decided to take it to Samsung Service center.. They tried to change the software version and I had some different baseband version which according to them is latest. I got the mobile next day but that also didn't solved the issue.
    I called them up again explaining the scenario and they said if its not the software issue then they have to replace the motherboard.. Now today i have again given them the mobile and they will replace the motherboard,...
    I don't know if its good or bad but i was personally afraid to keep a phone(motherboard) which is freezing like this. :/
    Lets see what happens next...!
    Thanks,
    Pranav
    02-04-2013 02:48 AM
267 1234 ...
  1. Replies: 15
    Last Post: 06-09-2013, 07:43 PM
  2. Just upgraded to Gnex and my 4g drops every few minutes
    By Bleezy in forum Verizon Galaxy Nexus
    Last Post: 04-11-2013, 12:31 PM
  3. Resale value of the Galaxy S3 in a few months???
    By rebelguy in forum Verizon HTC Rezound
    Last Post: 07-17-2012, 05:08 PM
  4. Resale value of the galaxy s3 in a few months?
    By rebelguy in forum Verizon Galaxy S III
    Last Post: 07-16-2012, 06:41 PM
  5. Locks up every few minutes
    By aprresley in forum Sprint Epic 4G
    Last Post: 09-01-2010, 07:26 PM
