06-03-2014 03:20 AM
267 ... 34567 ...
tools
  1. Vasko Bozinovski's Avatar
    Guys I believe I have found the fix!
    I started getting this annoying error last night and the phone would keep on freezing every few minutes then I'd have to force reset it by battery pull. Quite frankly I've been using android since the Dell Streak but I'm getting sick of these stability issues... Prior to that had an iPhone 4.
    I too had a recent upgrade from 4.1.1 to 4.1.2 on my SGS3 i9300 as I lived along with the fear of the Sudden Death Syndrome...
    On 4.1.2 I thought great... No SDS the phone should now work brilliantly...
    I read through this forum post and a few others and did experience the quicker lockups when on WIFI... Basically me symptoms....
    What fixed it for me?
    1. go to the applications manager under settings
    2. Uninstall all updates to that annoyingly stupid "Samsung Apps" app and revert the app to factory install.
    Bingo.
    Problem gone.
    I reinstalled the Samsung Apps update after opening the app and it didn't crash yet but felt lagging somewhat so I removed the updates again.
    What made me think it was this causing the problem is because from all the forum posts I've read people are suggesting its the ROM not specific apps users install. But hey... The Samsung App app is preloaded.
    Let me know how you all go after trying my fix.
    I suspect there must've been an error with one of the Samsung app updates along the way..
    Sent on my iPad2
    02-23-2013 10:07 PM
  2. Hassan K. Malik's Avatar
    Everyone having problems with their phones freezing, my suggestion is to remove their External SD cards and then try running their phones...
    Galaxy S3 has the knack of messing up the External SD cards....
    Sent from i9300 using Android Central.....
    02-24-2013 09:33 AM
  3. skyjuice7's Avatar
    I face this problem for quite number of days, finally after i follow the suggestion "Hassan" the freezing problem is now gone. !!
    02-25-2013 12:57 AM
  4. Lukus Lockus's Avatar
    I am still having the same issues.
    Here is what i tried so far:
    - Disable the Animations in the debug settings
    - Limit Background Processes to 2 (debug settings)
    - Uninstall Facebook App
    - Remove SD Card
    - Set Samsung Apps back to factory status
    Didnt help. Are there any other suggestions i can try?
    02-26-2013 01:51 AM
  5. stanoislav's Avatar
    Upgraded to I9300XXEMB1, no freezing so far. Fingers crossed.
    No freezing anymore
    02-26-2013 02:27 AM
  6. Lukus Lockus's Avatar
    So basically I have to void my warrenty in order to use my phone again, since for me the I9300XXEMB1 rom is not available over the air or kies...
    damn you samsung. I trusted you.
    02-26-2013 03:15 AM
  7. Hassan K. Malik's Avatar
    Try cleaning the dalvik cache and wipe cache partition other than removing or replacing your Ext SD card... Hopefully u should be OK...
    02-26-2013 09:34 AM
  8. tricia.dawn.williams's Avatar
    Hi everyone from experience try nothing. This is a software problem. Wait a bit for the update that I received on my mobile last week and install that. It will sort everything. My phone is even faster now too.
    Sent from my GT-I9300 using Android Central Forums
    02-26-2013 10:39 AM
  9. j_castell's Avatar
    Did the freezing dissapeared with this rom?
    I'm downloading as we speek to try it.
    02-26-2013 05:37 PM
  10. tricia.dawn.williams's Avatar
    Yes it did.
    02-26-2013 11:57 PM
  11. Lukus Lockus's Avatar
    Are you kidding me? So my options are: Void my warrenty, send in my phone or dont use my phone untill eventually there wil be a (possible) update... call me old fashioned but that doenst sound like how a valued customer should be treated...
    @Hassan: Tried cleaning all my caches. Still no change. Thank you for your continued efford tho.
    02-27-2013 02:26 AM
  12. Ivo Ferreira's Avatar
    Hi,
    Trying this:
    -back up sd card information
    - format sd card and unmount
    - factory reset
    for now everything is working great no frezzing
    02-27-2013 06:48 AM
  13. j_castell's Avatar
    Done the update to I9300XXEMB1 Rom and all day long without freezing. Seems to be the solution.
    02-27-2013 01:25 PM
  14. MG Dan's Avatar
    Been watching for a while now and finally signed up NOW THE BAD NEWS!!!
    I had no problems until recently, as per others, then I updated to I9300XXEMB1 and now my phone is a nightmare.
    Every day having to restart, force close or battery out.
    Almost wondering if its a longevity issue with the phones!!!!!!!!!
    Really very unhappy. Love the phone, left apple as many did but this could put me back to the darkside
    02-27-2013 03:31 PM
  15. j_castell's Avatar
    I have a whole day without any issue. This rom is only for the international version of I9300.
    02-27-2013 06:00 PM
  16. MG Dan's Avatar
    This was sent to me OTA on an original unbranded s3 never played with
    02-27-2013 06:53 PM
  17. Lukus Lockus's Avatar
    Just for the record:
    My phone mysteriously started working normally again yesterday night. No issues for at least 16 hours. I didnt change anything. That is really really wierd... well I am happy for now...
    02-28-2013 02:55 AM
  18. Mrlovkim's Avatar
    Sorry to hear you guys have these issues. mine is the international version and have had no issues and seems this is the only place I have heard of this problem. I don't root or do the custom roms with mine, like it the way it is.
    Hope your problems get resolved.
    02-28-2013 05:33 AM
  19. stoneleafuk's Avatar
    As suggested -
    Un installed all the samsung app store rubbish and my phone is alive again!!!
    I will update if i go down "insta death" again
    02-28-2013 10:30 AM
  20. MG Dan's Avatar
    As suggested -
    It won't let me uninstall the samsung apps? Do you have to root it to do that?
    Any help gratefully received. Had to remove battery twice today and force close with the power button once. No apparant reason!
    Thanks
    ITS OK I've done it will let you know if it makes mine stable again!
    02-28-2013 03:27 PM
  21. BigBenO's Avatar
    This is getting very frustrating now. I have been getting these ever since the firmware was updated to I9300XXELLA. I have tried the following
    - Factory restore twice
    - Formatted the external SDcard
    - Removed the external SDcard
    - Uninstalled all apps and restores them 1 at a time
    - Uninstalled the samsung apps updates
    It had slowed down to happening once a day but now it is happeneing everytime I pick up the phone. There is still no I9300XXEMB1 on O2 in the UK according to Kies and OTA. Is there anything else I can try apart from waiting for an update that may never come. I'm almost ready to throw the phone through a window.
    Thanks
    03-01-2013 05:49 AM
  22. Hassan K. Malik's Avatar
    Thanks
    Download XXEMB1 http://www.mediafire.com/?nno9z7w1fxr6zxp
    03-02-2013 01:30 AM
  23. Hassan K. Malik's Avatar
    Yes it did.
    R u using a custom ROM?
    03-02-2013 02:15 AM
  24. tricia.dawn.williams's Avatar
    No I am not. I have never touched the phone.
    But I swear mine is working perfectly now.
    03-02-2013 02:19 AM
  25. Jerome10's Avatar
    I am trying to be patient, but I seriously want to throw this piece of junk out the window. It is nearly unusable. Yesterday it froze with my alarm going off. That was about the end.
    Still waiting for OTA or Kies update of this new firmware. Don't know why I haven't gotten it. German phone, purchased unbranded, unlocked, "international" version. Still no update for 2 weeks.
    Phone not rooted. Totally stock.
    This better come soon...
    03-02-2013 04:24 AM
267 ... 34567 ...
  1. Replies: 15
    Last Post: 06-09-2013, 07:43 PM
  2. Just upgraded to Gnex and my 4g drops every few minutes
    By Bleezy in forum Verizon Galaxy Nexus
    Last Post: 04-11-2013, 12:31 PM
  3. Resale value of the Galaxy S3 in a few months???
    By rebelguy in forum Verizon HTC Rezound
    Last Post: 07-17-2012, 05:08 PM
  4. Resale value of the galaxy s3 in a few months?
    By rebelguy in forum Verizon Galaxy S III
    Last Post: 07-16-2012, 06:41 PM
  5. Locks up every few minutes
    By aprresley in forum Sprint Epic 4G
    Last Post: 09-01-2010, 07:26 PM
