The screen takes 76% of battery life
Het there
I just bought my new s3 one month ago and i had problem with my battery life.
My battery is goin low very fast and when i go to settings i saw that the screen takes 76% of my battery life.
My brightness is the lowest and the stand by is just 30 sec.
What can i do to fix that?
Thanks for your help
Re: The screen takes 76% of battery life
Thats normal mate. Its a big nice screen.
Its just a percentage so dont worry unless youre gettin REALLY bad battery life or if this happens while the phone isnt bein used ;)
quadcore 1gb GS3, Neat Rom by Salesale. Paisley, Scotland, Western Europe :beer:
The screen on any smartphone is the most power hungry part.
Sent from my GT-N7100 using Android Central Forums
Specialy a screen like this.
Black uses no power though so say online reading stuff, use the "inverted colours widget"
Try reducing the standby time to 15 secs....
Sent from my GT-I9300 (Hassan Khalid Malik) using Android Central Forums
