Results 1 to 4 of 4
    Default Charging & Battery Problems after 4.1.2 upgrade
    Since upgrading my i9300 drom ICS to the official 4.1.2 jellybean , I have been experiencing problems with Charging the phone, the charging icon will show that its charging, but the battery go down instead. I've had to switch off the phone in order for it to charge. I un-installed & minimized the use of apps that run in the background but still.. is anyone having same problem after the upgrade ? Like is it a general problem wt the Jellybean? I'll appreciate help or suggestions.. tnx
  2. #2
    Default Re: Charging & Battery Problems after 4.1.2 upgrade
    I've had the same problem after updating my phone but is only when charging the phone trough the usb and the computer, realized that it worked fine with the wall chargin
    Sent from my GT-I9300 using Android Central Forums
    It's funny cos mine also turned out to be the charger's fault.. so often we blame software when it's actually hardware problem. Tnx for d heads up..
  4. #4
    Yes sometimes it could be charger's fault. But mine is original charger came with the phone. Just bought 5 months ago. Shouldn't be charger's fault as soon as this time.
  1. Battery dying after 4.0.4 upgrade
    By levyashin1981 in forum General Help and How To
    Last Post: 10-28-2012, 05:55 PM
  2. battery charge % going up even after disconnecting charger
    By rakasaka in forum Google / Samsung Galaxy Nexus
    Last Post: 09-21-2012, 11:27 AM
  3. Charging/Battery issues after S-OFF
    By bislexic in forum T-Mobile HTC Sensation
    Last Post: 07-31-2011, 08:01 PM
  4. Battery problem after deleting stats
    By anicholas7 in forum Verizon Droid Incredible
    Last Post: 12-06-2010, 02:25 PM
  5. Battery problems, won't charge. Looking for advice
    By jmusso in forum AT&T Captivate
    Last Post: 11-18-2010, 09:31 AM
