1. Elias Bounader's Avatar
    Hey, i'm new to the forums but i really need this fixed. I flashed my S3 kernel to that of a Galaxy note. So of course screen burnt out and i got it replaced. Everything is fine except the fact that the phone reboots itself constantly. The bluetooth won't turn on either. If i tap the on button the phone freezes and then shuts itself off and restarts. I can't even say it has good periods. It just keeps rebooting. I've done everything. Here's a list.
    - Flashed to Stock
    - Flashed to custom
    - Clear Cache
    - Clear Davlik Cache
    - Full Wipe
    - No SD Card
    - SD Card
    - No Sim
    - With Sim
    I turned off wifi and it seemed to last longer... By longer i mean 5 minutes. The device also shut down when i put it to sleep.
    Please i really need help... Thank you in advanced.
    08-23-2013 07:29 PM
  2. Jeremy_Collinsworth's Avatar
    You've tried everything I would recommend, so another replacement for you my friend. It's probably hardware related or something really screwy in the root folder
    08-23-2013 10:14 PM
  3. Elias Bounader's Avatar
    The phone is under warranty but i'm not sure for which country... How can i flash on a mac? Any ideas? I think if anything the bluetooth might not be plugged in and is causing it to shut down? but it is... ugh so confusing
    08-24-2013 03:01 AM
  4. Jeremy_Collinsworth's Avatar
    Just call Samsung, they should be able to tell you where it can be serviced or you can send it in to them
    Sent from my SAMSUNG-SGH-I747 using AC Forums mobile app
    08-24-2013 09:54 AM
  5. Elias Bounader's Avatar
    I did and they claimed that it was from another country so they didn't have the correct parts... But it's the international version (i9300) and i'm in Australia
    08-24-2013 11:13 PM
  6. Jeremy_Collinsworth's Avatar
    Yeah, they rarely have parts for it. I've heard Samsung UK is like the only one with parts. Hmm.... Not quite sure what to do at this point. It needs to be repaired or replaced, that's for sure, but it's hard to find a place that will. I would just ask Samsung to call around and try to find a place with parts (like Samsung UK) and ship it to them. Somebody has to have parts, it's just finding out who. If it's under warranty, it's their issue to fix it period
    08-24-2013 11:22 PM
  1. Help phone's stuck at the black screen wtih Samsung displayed
    By rockstar8577 in forum Samsung Galaxy S3
    Last Post: 08-05-2016, 02:07 AM
  2. S3 Mini problems...
    By Dara McCormack in forum Samsung Galaxy S3 Mini
    Last Post: 01-09-2016, 10:48 PM
  3. Help with a Bizarre Google Drive App Crash Issue
    By Seth Kaufman in forum General Help and How To
    Last Post: 10-01-2013, 04:51 PM
  4. Wierd problem - help!!??
    By gbrown227 in forum Samsung Galaxy S3
    Last Post: 08-24-2013, 01:22 PM
