My S3 before I go to bed is at 50-60%,and when I wake up its at 5%???Please help me..
Hi. Have you turned your phone off and back on again since you applied the update?
I applied the update to my S3 Mini last weekend and ever since then I had the battery draining problem. I'd have to leave the phone on the charger overnight then at least the charge would last til I got home. Yesterday I experimented to see how long the charge lasted and, sure enough, the battery went flat. I stuck it back on the charger at about 3am and it was recharged when I left for work this morning. Its now 6:30pm (I'm in Australia) and the battery still has 85% charge!
I'm guessing the phone need to be restarted for the update to work properly. (I remember reading during the update that I should restart the phone but I assumed the restart it did during the update covered that. But perhaps not.
Anyway, I hope this helps
Mineis still worst even though i am charging whole ni8, sometimes it is not charging at all yesterday when i am going to bed it is 15%, when i woke up in the morning also it is same 15% even though i had plugged in
I shut down all non-essential apps, put the thing in battery saving mode, replaced the battery, charged the battery overnight with the phone OFF, and I was *still* having battery drain problems. I read on another forum that replacing the SIM card helped someone else...and I did that today and...VOILA! It worked! Now I'm doing my happy dance.
Assuming that your variant uses a SIM card (I've stopped trying to keep track of which models do and which ones don't), you should be able to get a replacement from any corporate store.Do you get another SIM from your carrier? Mine is AT&T, will they do that?
