1. Ivan Mihalic's Avatar
    My S3 before I go to bed is at 50-60%,and when I wake up its at 5%???Please help me..
    08-27-2013 06:13 AM
  2. MikeLeach's Avatar
    I use Battery Defender - works brilliantly
    other battery apps are available
    08-28-2013 06:09 AM
  3. NotaTechy2's Avatar
    Hi. Have you turned your phone off and back on again since you applied the update?
    I applied the update to my S3 Mini last weekend and ever since then I had the battery draining problem. I'd have to leave the phone on the charger overnight then at least the charge would last til I got home. Yesterday I experimented to see how long the charge lasted and, sure enough, the battery went flat. I stuck it back on the charger at about 3am and it was recharged when I left for work this morning. Its now 6:30pm (I'm in Australia) and the battery still has 85% charge!
    I'm guessing the phone need to be restarted for the update to work properly. (I remember reading during the update that I should restart the phone but I assumed the restart it did during the update covered that. But perhaps not.
    Anyway, I hope this helps :-)
    08-30-2013 03:31 AM
  4. GTWalling's Avatar
    Your screen shot is showing a total of 22h 19m on Battery. This is really great battery life. I really don't see a problem.
    09-01-2013 02:37 PM
  5. Hikmat abdoollayev's Avatar
    Another alternative app:
    "Wakelock detector"
    You can monitor what is draining your battery when it is idle
    Wakelock Detector Shows You the Apps that Keep Your Phone Awake
    09-24-2013 12:00 AM
  6. Golfdriver97's Avatar
    Welcome to the forums!
    Have you tried clearing cache in recovery?
    Sent from a Slim 4.3 S3
    09-24-2013 07:10 AM
  7. Tommy1491's Avatar
    I also face this problem. My battery drains very fast. I have tried to find out which apps use the most battery but found nothing. I just bought my phone for only 2 months.
    Posted Android Central App on Samsung Galaxy S III Mini
    09-28-2013 08:49 PM
  8. xtine1024's Avatar
    I shut down all non-essential apps, put the thing in battery saving mode, replaced the battery, charged the battery overnight with the phone OFF, and I was *still* having battery drain problems. I read on another forum that replacing the SIM card helped someone else...and I did that today and...VOILA! It worked! Now I'm doing my happy dance.
    10-11-2013 08:17 PM
  9. sai potla's Avatar
    Mineis still worst even though i am charging whole ni8, sometimes it is not charging at all yesterday when i am going to bed it is 15%, when i woke up in the morning also it is same 15% even though i had plugged in
    10-16-2013 12:13 AM
  10. Faultymango's Avatar
    Mate. I'd recommend trying a different usb cable. The stock Samsung cable has only 4 contacts inside the micro usb. BUT if you get a different one (I used the usb cable from my HTC one) it'll most likely have 5 contacts. I think this may improve charging times. Give it a try and get back to us and tell us how it went.
    Cheers!!!
    Sent from my GT-I9300T using Tapatalk 4
    10-17-2013 03:02 AM
  11. manowar669's Avatar
    I read this on another thread about this problem. Do you get another SIM from your carrier? Mine is AT&T, will they do that?
    10-11-2014 08:57 PM
  12. GSDer's Avatar
    Assuming that your variant uses a SIM card (I've stopped trying to keep track of which models do and which ones don't), you should be able to get a replacement from any corporate store.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    10-17-2014 09:05 PM
  1. Galaxy nexus stuck up at boot screen (phone not rooted)
    By Wirelessdroid in forum Google / Samsung Galaxy Nexus
    Last Post: 08-28-2013, 03:42 PM
  2. Galaxy S4? Galaxy S4G?? What's the difference????
    By MarvinJS#AC in forum Verizon Samsung Galaxy S4
    Last Post: 08-28-2013, 12:26 AM
  3. SAmsung Galaxy Ace 2 i8160 stuck on bootscreen after Root
    By Cosmescu Alex in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-27-2013, 09:06 AM
  4. Galaxy SII for Sprint - Keeps rebooting when I connect to Wi-Fi....Help!!!!!
    By fashionguy1980 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 08-26-2013, 09:28 PM
  5. Specifics on battery life. I like music. ;)
    By Grawbad in forum HTC One M7
    Last Post: 08-26-2013, 09:23 PM
