Results 1 to 5 of 5
    Default
    When i connect my headphones to my phone, music or sounds won't play, then if I disconnect the headphones and put pause and then play without the headphones first it works then finally plug them in and they work to. Why? How can I solve this?
  2. #2
    EviI's Avatar
    Posts
    Global Posts
    237 Global Posts
    ROM
    Stock 4.4.2 KitKat
    Default Re: Audio Problem
    It's either an issue with your headphones or your audio jack on your phone. Have you tried using your headphones with other devices?
  3. #3
    Have you tried cleaning out the audio jack with compressed air?
    Or, shut the phone off, take the battery out and then use a sewing needle to dig out any gunk/fluff/pocket lint that might be in there.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    I don't think it's a hardware problem but a software one I have Samsung galaxy s3 with CyanogenMod 11
  5. #5
    Quote Originally Posted by Felipe Van Der Donckt View Post
    (It would have been nice to know that up front)
    How did this behave on the stock firmware?
    Are you running a stable build or a nightly build?
    Have you checked the CM forums/website to see if others are having the same issue?
  1. Audio Problem
    By jcuadra21 in forum Samsung Galaxy S3 I9300
    Last Post: 12-13-2013, 10:27 PM
  2. S4 WiFi hookup problem solved
    By Rockman59 in forum AT&T Samsung Galaxy S4
    Last Post: 12-12-2013, 10:21 PM
  3. Is new 2013 ASUS N7 LTE suffering reboots problem?
    By Nidwow in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-12-2013, 04:49 PM
  4. Problems Viewing Video on HTC One (4.3)
    By Andrew Courtney in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-12-2013, 01:57 PM
  5. AT&T Samsung Galaxy S4 - WiFi hookupi problem solved
    Last Post: 12-12-2013, 01:51 PM
B
