Results 1 to 3 of 3
    Default S3 Stuck on Splash Screen. Please Help!
    Yesterday my phone decided to update to 4.3 and it went off without a problem, however 2 and half hours in it was stuck on the samsung splash screen. It vibrates every so often, it charges fine and sometimes my lock screen loads up [after 30minutes or so of it being on the samsung logo] only for it to turn off and start again. The Recovery and Download functions work as well. Kies won't recognise it. My Laptop sees the phone but can't open any files.
    I seem to have tried everything under the sun besides Odin at this point.
    I have removed battery - it's the same
    I cleared the cache - nothing.
    I have connected it to kies - won't recognise it.
    I have used a different charger - nope.
    I have used a different battery - nope.
    I have never installed roms or done anything to my phone besides updating it when it comes up.
    I know I can restore to factory settings, but I really don't want to as I was to keep my files.
    Please help! I will forever be indebted to whomever saves me from this problem!
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: S3 Stuck on Splash Screen. Please Help!
    Quote Originally Posted by Alexandra Ribeiro View Post
    I would suggest a Factory Restore. You won't loose the data on the sd card(s), but all other information (Apps, App data, unsync'd contacts and text messages) will be gone. Seems to be the only way to get it restored since the device is boot-looping. This could have been caused by a bad download or a conflict during the update process. Either way, a restore should fix the problem. If not, you may need to contact the carrier or manufacturer and see how they can help you restore. Likely by flashing stock firmware via Odin.
    Thank you. I decided to flash my phone with Odin and now it works. I still have my files as well.
  1. Replies: 5
    Last Post: 02-04-2014, 10:39 AM
  2. tab 3 10.1 - can't turn on wifi
    By Jarrad S in forum Samsung Galaxy Tab 3
    Last Post: 02-04-2014, 04:51 AM
  3. S3 severe battery drain
    By HelpNeededSlll in forum Samsung Galaxy S3 I9300
    Last Post: 02-02-2014, 12:25 PM
  4. Galaxy S3: laggy music playback
    By hasaan001 in forum Samsung Galaxy S3
    Last Post: 02-02-2014, 09:08 AM
  5. I'm like freaking out - my tablet won't turn on
    By Billie Piper in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-01-2014, 07:31 PM
