Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By UJ95x
  • 1 Post By GTWalling
    Default Storage problem in gs3
    I am using supernexus 4 android versio 4.4.2
    My memory shows dat only 1.5 gb internal memory is being used in apps, photos, etc but still only 2.6 gb free.. Although the internal memory is 16 gb and the memory given for apps etc is 11.8 gb
    I want to add a screenshot for more details but since i am new on android central i dont know how it is to b done.
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default Re: Storage problem in gs3
    Quote Originally Posted by varunmehta1997 View Post
    Welcome to Android Central
    There was a similar thread from a while back: Galaxy S3 - it says that memory is full while it isn't
    Try what they recommend in the second page
    varunmehta1997 likes this.
    Man i appreciate ur work but i didnt get any satisfactory answer. The solution given there works for phones with stock rom.
  4. #4
    It also helps us to help you by know as much detailed information as possible. The simple things such as Model of Phone and Provider. Also posting in the appropriate forum may help. You state you are using a "supernexus 4" and this is the Galaxy S3 forum.
    UJ95x likes this.
  1. LG G2: problem when flashing customROM 4.4 AOSP
    By Brandon Shea in forum LG G2
    Last Post: 06-01-2014, 09:12 AM
  2. Exchange : Cannot send email in HTML format
    By soryuuha in forum Droid RAZR M
    Last Post: 02-25-2014, 04:04 AM
  3. audio problems with video camera
    By animaledizona in forum Samsung Galaxy S3 Mini
    Last Post: 02-07-2014, 03:29 PM
  4. Replies: 5
    Last Post: 02-07-2014, 02:05 PM
  5. SD card problem- faulty slot?
    By Rossotron in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-07-2014, 10:19 AM
