1. elilopes's Avatar
    Good morning, Problem: black screen, cell does not unlock and screen does not light. Only led illuminates
    Bom dia, algum conhece esse problema? se tem soluo
    Good morning, someone knows this problem? has solution
    Buen das, alguien sabe deste problema? tiene solucin
    Vdeo -> youtube.com/watch?v=WmlbFQ9jQkQ
    02-26-2014 09:26 AM
  2. GSDer's Avatar
    It sounds like the screen has failed (perhaps because of being dropped or some other impact). If you've tried booting into Recovery mode or Download mode and the same thing happens, it's time to replace the screen assembly. Here are a couple of sources:
    Parece que a tela falhou (talvez por causa da queda ou algum outro impacto). Se voc j tentou arrancar em modo de recuperao ou modo de download e acontece a mesma coisa, hora de substituir o conjunto da tela. Aqui esto um par de fontes:
    http://m.repairsuniverse.com/samsung...ent-white.html
    http://www.etradesupply.com/samsung-...-assembly.html
    02-28-2014 03:26 AM
  1. Mattress suggestions - want one that lasts, what do you like?
    By HelloNNNewman in forum The Android Central Lounge
    Last Post: 03-02-2014, 09:45 AM
  2. Replies: 11
    Last Post: 02-27-2014, 11:45 AM
  3. "Flappy Bird - no ads" on Samsung App Store...Malicious?
    By clborden in forum Samsung Galaxy Note 3
    Last Post: 02-26-2014, 10:35 AM
  4. No SIM card - Emergency calls only
    By briancook451 in forum Google Nexus 5
    Last Post: 02-26-2014, 10:13 AM
  5. Samsung Galaxy S3 BLANK SCREEN NO DISPLAY
    By FL OZ in forum General Help and How To
    Last Post: 02-25-2014, 08:55 PM
