Results 1 to 2 of 2
    Default Having problems charging your Galaxy S3 CHARGING SOLUTION
    Hi everyone,
    I had a very similar problem that is being discussed and followed most of the tips but without success.. (new adapter, battery, charge point etc etc)
    I have now identified the problem and thought I would share..
    1) get a pin
    2) go under a strong light with your phone
    3) clear all debris from the charge socket on the phone
    4) using a pin place it inside the charge point and below what appears to be the connection point ( there is a small chip set looking thing inside the socket)
    5) gently raise it with the pin by applying some pressure so that the connection point raises up slightly
    6) connect and job done it should charge normally.
    I think by using the chargers aggressively it bends the connection point within the socket and this causes the problem
    if you have any questions I am happy to help as it was soooo frustrating and I want to help others before they spend money on fixes that probably wont work
  2. #2
    Default Re: Having problems charging your Galaxy S3 CHARGING SOLUTION
    You may want to edit your post to include a note to remove the battery before starting any of this - it's not a good idea to be fiddling around with electronics with power available.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
  1. Stock ROM For Samsung Galaxy Note Pro 12.2" - SM-P900 (Best Buy - US)
    By Stephen Wayne Hamilton in forum Samsung Galaxy Note Pro 12.2
    Last Post: 05-04-2015, 05:58 PM
  2. Phone not responding to Hi galaxy
    By claudiuid in forum Samsung Galaxy S4 Mini
    Last Post: 04-05-2014, 05:35 PM
  3. Connecting two bluetooth headphones to S3 at the same time
    By mpadhu in forum Samsung Galaxy S3
    Last Post: 03-24-2014, 12:22 PM
  4. What is your favorite app to learn Geography?
    By jim goodman in forum Android Apps
    Last Post: 03-24-2014, 02:26 AM
  5. Samsung galaxy s4 message notification in lockscreen problem?
    By pipenz11 in forum Samsung Galaxy S4
    Last Post: 03-24-2014, 01:20 AM
