1. LauraBunnyyy's Avatar
    Hello all!
    After updating my phone to 4.3 I find I am having to charge my phone up to 5 times a day! I also have to carry round a wireless charger and a spare wall charger with me at all times as my phone will die whilst I am at work for sometimes as little as 5 hours, bare in mind I won't even use it for 4 hours of that time.
    I have wifi disabled when I am not at home, and have no apps running in the background. I also have a battery saver app. But it is still draining sooo fast. It's ridiculous!
    When it gets down to about 20%, the screen flickers and I lose all signal and it's basically useless until I can charge it.
    Any suggestion on what I can do? As this is very silly and I am not always near a plug to charge!
    Many thanks.
    03-27-2014 10:14 AM
  2. Spencerdl's Avatar
    Sounds like a battery problem. Is that the original battery?
    03-27-2014 10:40 AM
  3. LauraBunnyyy's Avatar
    Yes it is the original battery. It only started happening after updating to 4.3
    03-27-2014 10:48 AM
  4. GSDer's Avatar
    I'd start with a Factory Reset (after backing up your important information of course) along with wiping the system cache in Recovery mode.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    03-27-2014 11:53 AM
  5. LauraBunnyyy's Avatar
    I have done all of that Tried it a few weeks ago and no change.
    03-27-2014 03:47 PM
  6. GSDer's Avatar
    Well, you can either completely reload the 4.3 firmware, or invest in a replacement battery.
    03-27-2014 05:14 PM
  7. Spencerdl's Avatar
    I'm thinking you probably need a new battery.
    03-27-2014 05:50 PM
  8. saab61's Avatar
    i have the same problem and recently started an thread about it. it is not the battery. i replaced the battery and the drain dint disrepair. i even tried a zerolemon 7000mah extended battery. still there was a very high drain. no deepsleep!
    04-02-2014 12:55 PM
  9. fesouza's Avatar
    Hello Laura,
    Try to leave your S3 for a couple of hours disconnected (no wifi and no mobile data) and see if the battery drain is reduced.
    04-02-2014 04:20 PM
  1. AT&T Note 3: KitKat is rolling out today some already getting the update
    By zaydabarber in forum Samsung Galaxy Note 3
    Last Post: 03-30-2014, 02:20 PM
  2. Clock wallpaper on Samsung Ace 2
    By Garden123 in forum General Help and How To
    Last Post: 03-28-2014, 07:00 PM
  3. Galaxy S4: Battery life
    By Yousef Amarneh in forum Samsung Galaxy S4
    Last Post: 03-28-2014, 08:18 AM
  4. battery life. was great, now not so much
    By 4m0wagen in forum Samsung Galaxy Note 3
    Last Post: 03-28-2014, 01:10 AM
  5. HBOGo app not working on GS4 and Nexus 7 2013
    By bobbob1016 in forum Android Apps
    Last Post: 03-27-2014, 09:58 AM
