Results 1 to 4 of 4
    Default Battery drain on S3
    my phone battery is draining fast. It happened before and i factory reset my phone then it was fine but later it started again but this time i dont want to factory reset my phone please help me to solve this issue
  2. #2
    Default Re: Battery drain on S3
    Quote Originally Posted by Imran Manzoor View Post
    Force update your phone vie kies
    1, remove battery from the phone and DO NOT PUT BACK IN for the remainder of these instructions
    2, underneath the battery on the phone is the imei# and serial#
    3, you need the serial# and leave the battery out for this task
    4, now start Kies that is on your P.C and make sure you have a internet connection
    5, from the menu bar go to Tools and select firmware upgrade and initialization
    6, enter the model GT-I9300 (make sure its CAPITALS GT-I)
    7, enter serial# (CAPITALS again)
    8, press OK to initalize (dont worry you should not have a battery in )
    9, this will now give you the string = Initialised version PDA:*** / PHONE:*** / CSC:*** (***)
    start update
  3. #3
    Main cause is background application install any task killer available on playstore.
    it may seem zero but many bakcground processes are always on they again reopen wh you close them
    keep brightness zero
    turn off wifi bluetooth and data connection off when not in use.
    still facing problem try formating or calibrate ur cell battery with following instruction once in every 2 months
    [BOX=undefined]-Let the phone battery run out of charge, to 1 % or zero is better (preff 1 % bcoz zero battery can sometimes make your phone dead-then u hav to rely on phones warranty )
    -remove battery after 15 min reinsert battery
    -Charge the phone fully without turning on your phone in one go with no breaks
    -Once it is fully charged, turn it on and leave it untouched for 30 minutes.
    -Again plug in the charger and allow it to charge for another 30 minutes, don’t use it in between.
    -Once the battery is fully charged, unplug it and your battery is now calibrated.
    hope your problem is solved .
  4. #4
    Quote Originally Posted by KALPESH23 View Post
    Task Killers are bad and unnecessary for Android systems. Read the link in my Signature.
  1. Printing on Samsung Note Pro 12.2
    By drrejensen in forum Samsung Galaxy Note Pro 12.2
    Last Post: 05-25-2014, 12:49 PM
  2. Extended Batteries
    By donb2010 in forum Samsung Galaxy Note 3
    Last Post: 05-14-2014, 09:58 PM
  3. Replies: 6
    Last Post: 05-12-2014, 04:28 PM
  4. battery
    By youngXXone in forum Sprint HTC One
    Last Post: 05-12-2014, 04:15 PM
  5. Apps/photos won't move/install to SD card on gs4
    By Tom Sz in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-11-2014, 12:27 AM
