Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By B. Diddy
    androidgirl3107's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Weird battery problem
    This is not the first time it happens. I play my phone until it got to 0% and it turn off itself. Then when I plug in the charger and turn it back on right away, 20% just came out randomly from nowhere(It suppose to be just 1% that time)
    I want to know if any S3 users experience this too.
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,903 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Weird battery problem
    I don't know this for sure, but I think battery readings toward the very low end can be somewhat erratic. The larger picture here is that it would be a good idea not to let your battery go to zero habitually, because that will increase the risk of allowing the battery to fully discharge to true zero (which is irreversible). For example, if your battery ran out, shutting the phone down, but then you got distracted and forgot to plug the phone in for the night--the little charge left in the battery could then completely run out, leaving you with a useless battery.
    GSDer likes this.
  1. 10,000 mAh battery needs to be standard in smart phones
    By datum9 in forum General News & Discussion
    Last Post: 12-25-2014, 06:45 PM
  2. blinkfeed battery drain
    By dynastorm in forum Verizon HTC One
    Last Post: 07-21-2014, 05:33 PM
  3. Replies: 0
    Last Post: 07-07-2014, 11:39 AM
  4. Any help with my battery issue?
    By classic20 in forum HTC One X
    Last Post: 07-07-2014, 10:42 AM
  5. What drains less battery, constant Bluetooth Scanning or Bluetooth Speaker Link?
    By SpookDroid in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 07-07-2014, 10:05 AM
