Results 1 to 3 of 3
    mega350's Avatar
    Posts
    ROM
    Stock for now
    Default LTE 10.1 will not connect to WIFI
    I've been connected to the same wifi router for almost 6 mnths. suddenly GTab will no longer connect. i know its not the router since all other devices hold a constant connection. The wifi status on the tab sits on 'Authenticating / Scanning' and my network status says 'Disabled.
    So far I have resetted router, forgotten and restored saved network on tab and completed master reset.... still a NO GO!!!!
    What am I missing? please help, vzw support is clueless, they suggested master reset after I said it's already been done. any advice will be greatly appreciated
  2. #2
    Default Re: LTE 10.1 will not connect to WIFI
    Did this happen after you installed the latest VZW update?
    mega350's Avatar
    Posts
    ROM
    Stock for now
    nope. im still on 3.1, havent recvd any recent updates
