Results 1 to 7 of 7
    Petros Solomos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default galaxy tab 10.1 p7510 problem help!!!!
    Hi!
    My P7510 is freezing and turn of by it shelf, when I turn it buck on it always start from the same point, even if I delete everything when it turns on they reappear.
    I have tried factory reset, hard reset even odin but nothing works it always come buck to the same point.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,070 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: galaxy tab 10.1 p7510 problem help!!!!
    Quote Originally Posted by Petros Solomos View Post
    Hi!
    Welcome to the forums. So, to clarify, you reflashed a ROM with Odin?
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, and it looked like it completed the process with no problem but when the tab opened nothing had change
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have just tried with checked re-partition and then with checked nand erase but odin fails both times Im starting to think that there is some problem with the internal memory.
  5. #5
    Posts
    Global Posts
    33,070 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I think you may be right. Especially if Odin is not fixing the problem.
    Sent from my HTC One_M8 using AC Forums mobile app
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is there a way to replace the nand?
  7. #7
    Posts
    Global Posts
    33,070 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I am not sure. Physically you should be able to replace the memory, but that most likely would require replacing the whole mother board.
  1. AT&T Galaxy Note 3 (Black)
    By jdevenberg in forum Marketplace Archive
    Last Post: 05-06-2014, 01:33 PM
  2. Problems with kitkat 4.4.2 update
    By shabnam sultana in forum Samsung Galaxy Note 3 in Canada (Bell/Rogers/Telus)
    Last Post: 05-06-2014, 12:51 PM
  3. Samsung Galaxy S3 - water damage (doesn't read SIM)
    By afonsom2 in forum Samsung Galaxy S3
    Last Post: 05-03-2014, 07:47 PM
  4. Tethering Galaxy s5 and Samsung Note 10.1 2014 Edition
    By Mason Burdette in forum Samsung Galaxy S5
    Last Post: 05-02-2014, 11:24 PM
  5. My Samsung Galaxy S2 got wet and now won't turn on.
    By Zephrix in forum General Help and How To
    Last Post: 05-02-2014, 12:03 PM
