1. ochness's Avatar
    I have a Samsung Galaxy tab 2 7.0. I have the USB adapter and am using the adapter to connect a USB bar code scanner to. The scanner worked just fine since I have had the tablet (about 2 months) then the battery died and now the tablet will no longer power the scanner when attached via the USB connector. When I connect the USB adapter with the scanner plugged in I can see on the top of the screen the USB symbol and it says "USB connector connected" but I get no power to the scanner.
    I'm not sure what happened as this was working. Any info and assistance is greatly appreciated.
    06-25-2013 11:48 AM
  2. extraclass's Avatar
    I have a couple adapters that are called OTG ADAPTERs and they supply power to a keyboard or mouse. One is a short pigtail with Samsung 30 pin on one end and a USB on the other end. The other is about an inch square and plugs into the 30 pin and provides a micro usb outlet! I have used them since the last software upgrade so I know that is not the problem! Be sure your adapter is an OTG adapter!
    06-25-2013 02:33 PM
  1. Windows 7 Android 4.2.2 ADB device offline and no prompt to allow USB debugging
    By androidluvr2 in forum Verizon Galaxy Nexus Rooting, ROM's, and Hack's
    Last Post: 10-13-2014, 08:42 PM
  2. Replies: 3
    Last Post: 05-10-2013, 02:09 PM
  3. USB to PC media device connection failure?
    By Roffles in forum Verizon Galaxy S III
    Last Post: 07-26-2012, 03:20 PM
  4. No Option to Connect USB
    By BelindaR in forum Samsung Galaxy S II Skyrocket
    Last Post: 07-03-2012, 06:12 PM
  5. Can't get phone to show up as a USB storage device
    By colonelcack in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 03-12-2012, 09:14 PM
