1. Andrew Macdonald3's Avatar
    So recently my tab has been charging much more slowly than it used to and at the same time has been draining very rapidly ie full battery used in less than an hour with standard use. Ive tried rebooting several times, have used battery doctor and even anti virus software to see if it could be a malicious download but nothing has worked.
    Im used to having issues with samsung batteries (galaxy s2 and s3) but precious tab is sick Im desperate to find a solution.
    Thanks in advance.
    03-28-2014 02:26 PM
  2. depechemodegurl's Avatar
    Thanks in advance.
    My tab does the same thing and there are tons of threads about it. The only fix involves taking off the back cover and disconnecting/reconnecting the battery wire. I haven't been brave enough to try it out to see if it works.
    Rockin my LG G2
    03-28-2014 06:00 PM
  3. bouldy's Avatar
    I have sent mine back too samsung for the 3rd time due too battery drain.a fully charged battery will discharge it self to empty in 2 days completely switched off
    09-17-2014 02:56 PM
  1. Galaxy S4: turn on while charging
    By longcafe in forum Samsung Galaxy S4
    Last Post: 08-11-2014, 11:35 AM
  2. battery issue with galaxy tab 3 8.0.. please help!
    By Andrew Macdonald3 in forum Samsung Galaxy Tab
    Last Post: 04-23-2014, 02:25 PM
  3. HTC One (M8): iPhone user with questions!
    By Lynx in forum HTC One M8
    Last Post: 03-30-2014, 02:08 PM
  4. Galaxy S4 says it's charging but it WON'T!
    By cberry30 in forum Samsung Galaxy S4
    Last Post: 03-28-2014, 03:28 PM
