1. Funkhauser's Avatar
    I know - I am not in the right forum but this is the closest device to my Android device.
    The Galaxy Player 5.0 is relatively new device that is very similar to the Apple Ipod Touch in that it is
    WiFi capable but is an Android device - no phone.
    Here is my problem:
    I subscribe to Rdio. I have about 10gb of music that I would like to sync to my Samsung player for offline use. The issue is that the songs automatically are being sent to USB storgae instead of the the 32gb microSD that is mounted in the card slot. I have checked all settings and the device definitely recognizes the card. Is there anyone who can figure out how to direct the songs to the SD card? I should note that the player is not plugged into the computer and it still stores in USB storage. My assumption was that when syncing the App would lookk for the largest storage area, but it is not.
    I would appreciate some direction.
    01-24-2012 05:35 PM
  2. Sonofaperson's Avatar
    i really hope im not to late (2 years late). i know how to move the music to the sd card but not automatically.
    go to the app files. scroll down a bit and you will eventually find a folder saying something like rdio or something similar to that. long click on it. a menu will appear. tap move. scroll down to a folder that says external sd. tap that. a little menu on the bottom will say either move here or cancel. tap move here. since it is such a huge amount. it will take awhile. hope this helps
    07-10-2014 10:06 AM
