Galaxy Tab Pro 12.2: Battery Drain
dsneedmd
206
My 12.2 will go to 80% from 100% in 3-4 hrs w/o being used & NO screen time. Settings says all drainage is due to Android OS!!?? I'm running 2 other devices on 4.4.2(Kit-Kat), my Nexus 7(2012) shows over 80% after 2 DAYs off charge. My GPS is off, any ideas? Help!!
Have you received an update to the device? Meaning, have you gone from say, 4.1 to 4.3?
I put the 12.2 on Power Saving mode & this helped some, but it's still way too battery hungry for a device that has 9,500mamps. Android system & android OS are using more power than the screen!?
Does it sit idle a lot?
From a Sprint Moto X using AC Forums app
As long as mine is on standby, even aftr and hour off the charger, it shows 99% battery when I start using it. Some background process must be using power.
r3dpuk3
