Results 1 to 3 of 3
    Default Galaxy Note Pro LCD and digitizer fused or separate?
    Hi,
    I dropped my Note Pro and the (12.2") screen is pretty badly cracked but the functionality is fine. I would like to know whether I can just replace the digitizer (which I have already ordered from China) or if this is fused to the LCD, in which case I would need to replace both presumably.
    Despite enjoying this tablet, there doesn't seem to be that much information on the internet regarding maintenance so any advice would be greatly appreciated.
    Thanks.
  2. #2
    Default Re: Galaxy Note Pro LCD and digitizer fused or separate?
    I too need to know this answer.... I have the same tablet, and if its the entire assembly then I'm not going to spend $200 bucks on it. If it's just the digitizer, I'm good with spending $65
  3. #3
    Touchscreen is only around $50 but LCD and touchscreen are glued with Optically Clear Adhesive ( OCA ) film. I think your chance of breaking the LCD is 90% if using heat gun and have no prior experiences
    They have special heat plate to heat up the LCD evenly and thin metal wire to separate the touchscreen and LCD. No experience you're more likely will cut or damage LCD flex cables as well as crack the LCD. Even if you can change it without damage to LCD, air bubbles between the two glasses are unavoidable without OCA film.
    After one hour of labor to heat up and separate the touchscreen, this is a test to make sure the LCD is not cracked or damaged
    Then another one hour to remove this clue:
    Here is a LCD assembly with new touchscreen without OCA film. I damaged 3 LCDs to learn how to replace the touchscreen.
    You can expect spending 3 to 4 hours to finish the replacement.
  1. Replies: 1
    Last Post: 03-09-2015, 08:48 PM
  2. Replies: 2
    Last Post: 11-04-2014, 03:44 AM
  3. Replies: 6
    Last Post: 07-30-2014, 03:31 PM
  4. Verizon Galaxy S5 Won't Receive SMS
    Last Post: 07-24-2014, 05:24 PM
