04-21-2016 08:58 AM
37 12
tools
  1. jwwilker's Avatar
    My fiance bought me the TabPro 8.4 for Valentine's Day, and I absolutely love it.
    We took a trip to Chicago this past weekend, and yesterday I noticed that the tablet's battery was dead (I thought she turned it off...she thought I did..). When I turned the tablet on, I got the "Critical Battery Level" warning, so I immediately plugged it in. It got to 12%, and we were ready to leave the hotel, so I turned the tab off and unplugged it. My thought was to charge it when I got to the airport. Well, when we arrived at the terminal and I plugged the tablet in, nothing happened. No charging indicator on the screen, the power wouldn't turn on, nothing. I assumed that it was just so dead and that's the reason why nothing was happening. We got home, and I plugged it in to the charger and left it overnight, and still nothing. This morning it will not turn on, it doesn't respond to the charging cable being plugged in...absolutely nothing.
    Do you guys have any thoughts?
    02-25-2014 09:07 AM
  2. the tall guy's Avatar
    The exact same thing happened to me with my Nexus 7 - I had to return it to the manufacturer (Asus) who advised me that it needed the connection cable replaced within the tablet, they fixed it and returned it to me free of charge as it was still within my warrently. I would suggest doing the same if it's not turning on
    02-25-2014 09:18 AM
  3. Golfdriver97's Avatar
    It may be possible that the battery dropped so low, that there are no not enough volts, essentially a bad cell, in the battery to turn it on. I would suggest to call Samsung and see what they suggest.
    02-25-2014 09:25 AM
  4. Wobblin30's Avatar
    I would return it for another one if your'e within the return period. My first 8.4 had two small scratches around the rear camera housing despite the box being factory sealed. I brought it back to Best Buy for an exchange the next day. The 8.4 is a new device so there are going to be a few bad apples here and there during the manufacturing process. Sounds like you have a dud that won't sort itself out.
    02-25-2014 11:14 AM
  5. jwwilker's Avatar
    I called Samsung, and they gave me a UPS label to return to their service center. I may try to swing it by Best Buy tonight to see if they can swap it so I'm not without a tablet for a couple of weeks.
    02-25-2014 02:23 PM
  6. the tall guy's Avatar
    Let us know how you get one, hopefully they replace it for you
    02-26-2014 07:59 AM
  7. mattskr's Avatar
    Just exchange it, Best Buy has excellent return policy. No reason to be without a tablet.
    02-26-2014 11:01 AM
  8. jwwilker's Avatar
    I took it by Best Buy last night. After dealing with their peachy customer service representative, I was told I needed to see the "Geek Squad" to have the tab looked at. Well, after waiting for an hour on the one geek squad rep to help countless old ladies set up their new computers, I got fed up and talked with a manager. He was polite enough to swap out the tab, and even gave me an invisishield for no charge to replace the one I had put on the original tablet.
    02-26-2014 01:26 PM
  9. Wobblin30's Avatar
    Good to hear you're up and running
    Posted from Moto X via Android Central App
    jwwilker likes this.
    02-26-2014 02:56 PM
  10. Stefon Sharp's Avatar
    I had the same problem, all I did was restart the tablet and now it's works fine. I suspect it's software or firmware. It does not have a short, it is either on or off. That's why I think it is not the charge port. They will probably have an update to fix it.
    03-01-2014 04:15 PM
  11. Haalcyon's Avatar
    Unacceptable. There is absolutely no reason or excuse why this should affect more than the rare 1 in 1000, if that. For it to be a software issue would be extremely unacceptable as charging your device is one of the very most basic things a customer does. This kind of thing happening on an Asus tablet is not surprising to me at all given the experiences I've had with their Transformer Primes but I would certainly expect better of Samsung given their primary competitive target.
    Sent from my liberated Titanium iPad Air LTE 
    03-01-2014 04:39 PM
  12. jwwilker's Avatar
    No, it wasn't a software issue with mine. It was the battery itself. Once the tab's battery lost its full charge, it didn't have enough voltage to do anything. I couldn't restart it (because it was already off), and a software update wouldn't have fixed it. I do feel that mine was a rare issue. I had the Transformer Prime, @Haalcyon, and trust me, this tablet is by far superior to that. I loved the Prime initially, but it just got bogged down immensely after a few days of use. I have had zero issues with my replacement, and don't expect to have any going forward.
    03-02-2014 09:15 AM
  13. Haalcyon's Avatar
    I'm glad your replacement is working fine. I still have a little faith in Samsung Mobile, basically, but they're not showing the attention to design, quality, and detail that I prefer and can get elsewhere. However, yes, they're still better than Asus in my book. Neither of them will miss me and I certainly won't miss them so everyone's happy.
    Sent from my liberated plutonium 5s 64
    03-02-2014 11:00 AM
  14. mattskr's Avatar
    Hmm, I've never actually let mine lose all of it's charge. Now I think I should to make sure I don't have this issue.
    03-02-2014 12:32 PM
  15. Haalcyon's Avatar
    I'm hoping that today's mobile electronics would shut themselves completely off before reaching a point to where the battery could be damaged by lack of charge. Am I expecting too much?
    03-02-2014 12:36 PM
  16. brosko's Avatar
    They do give you enough warnings that the battery is getting low and even the screen dims when it get to 5%. Enough warning IMO. People aren't going to listen, just like everything else in life.
    - - - Updated - - -
    This seems to be a common issue with Samsung devices. Very popular complaint in the tab 3 forum.
    03-02-2014 05:57 PM
  17. RBEmerson's Avatar
    This is a problem with other Android devices. Basically, if there isn't enough power left in the battery to do a minimal wake-up for charging, the phone is never going to wake up. Unfortunately, charging a tab battery isn't like charging a car battery: slap a charger across the battery and watch the joules roll in. There's logic involved in charging; if the phone can't supply power for that logic it's "movie over - go home".
    In the Motorola world, there's the Factory Programming Cable which supplies the needed power to wake the phone up enough to get it started. I suspect there's something similar in the Samsung world.
    03-11-2014 12:39 AM
  18. Haalcyon's Avatar
    Devices should power themselves off, no if's and's or but's, don't ask the user, just power down for self-preservation before the battery is in such a state that it doesn't have Enough to be charged. Why is this not the case?
    {iRiidium} Technophile. 2 of 4 
    brosko likes this.
    03-11-2014 01:04 AM
  19. brosko's Avatar
    you are 100% correct! they should give you all the warnings and when you don't heed the advice just shut down automatically before this happens.
    03-11-2014 05:22 PM
  20. TonyInDallas's Avatar
    I'm having a different problem. After running great for a week, as of yesterday my battery percentage is staying at 100%. I either have the greatest battery ever, or something's afoot. Anyone else seeing this?
    04-24-2014 11:56 AM
  21. bumblebeesarefuzzy's Avatar
    Yup -- after buying a galaxy tab in Jan. 2013 and accidentally letting the battery get too low, mine also wouldn't turn on. Just kept showing the battery charging symbol for days. Shipped it to Samsung, as it was still under warranty, they "fixed it" and shipped it back. Worked fine for months until yesterday I didn't realize the charger wasn't plugged in all the way and now the same thing has happened again (and warranty is up). I'm giving up and getting an iPad.
    05-17-2014 04:54 PM
  22. pamigramster's Avatar
    Have Galaxy tab 2 .. rooted .. was clearing the battery stats in advanced mode in recovery mode and hit the power button by mistake , unit never turned on again ,,, replaces the battery , nothing replaced the charging cord nothing ..... cold as ice to the touch ... kies doesnt recognize it .... what can I do ... out of warrenty ... have openned the case several times , have un plugged and replugged every connection ......
    Thanks
    07-15-2014 05:28 PM
  23. storino03's Avatar
    Wrong forum as this is for the Tab Pro 8.4 lol
    07-16-2014 10:25 PM
  24. koolvankleef's Avatar
    So it seems my Tab Pro 8.4 has the same problem. After some overnight use by my child. It now will not charge at all.
    I have tried exceptional long mains and trickle charges, all the various combinations of resets and even the unplugging the battery connection fix that apparently worked on the Tab 3.
    My major issue is that in my desperation for the LTE model, still unreleased in Britain, I bought an import model which of course comes with no guarantee.
    So in my mind the most likely issue is the battery is dead. Which leaves two options; I do know most dead batteries can be restored by a special form of charging, similar to the lead mentioned above. However tried to find the details of how to do this and also the wiring of the five or six leads that access the battery is information I have not found. It would be really good to test the output of the battery as well to confirm this.
    Failing that of course is replacing the Battery but again as it is reletively new product I have not seen the Battery available any ideas.
    My other possibility for the fault is off course that the charging port and circuitry has failed but again testing this would be very diffcult without any technical data.
    Any help would be gratefully received.
    07-23-2014 09:52 AM
  25. JohnMiller2013's Avatar
    I have had this issue with several tablets and one phone (when the battery drained all the way down to 0).
    The solution has always been to plug the unit into a working wall charger, and let it sit. Sometimes for days. Eventually, it turns on when pressing and holding on the power button.
    On my Nexus 10 tablet, I had to do something a little fancier to get it to turn back on though (pressing the volume rocker and power button at the same time, to put the device in a special state).
    Just to be sure we're understanding, keep in mind that when you tap the power button, your device is not "off"; it is in standby, draining battery. To truly turn it off, you have to press and hold the power button to get a prompt to turn off your device.
    08-18-2014 02:45 PM
37 12
  1. Full screen album art/tap to pay with kitkat?
    By drache713 in forum AT&T Samsung Galaxy S4
    Last Post: 03-04-2014, 08:33 AM
  2. Replies: 17
    Last Post: 02-27-2014, 07:35 PM
