1. Dualmonitors's Avatar
    I've read numerous times that Samsung's original, provided USB cables (and their associated devices) have reversed, internal wiring that make them unique and one cannot merely substitute any other USB to micro-USB cable from standard devices and use it without problems with these specific Samsung devices. This all started initially with the Samsung S3 and then even the S4 has these uniquely Samsung internally reversed wiring.
    May I ask if this is true?
    Also, my TabPro 8.4's included original USB is way too short for my needs. I have a Note 8 which has a longer included original USB cable. Would anyone know for certain if these are interchangeable? If so, i can swap the cables prior to selling the Note 8.
    Thank you very much in advance.
    03-14-2014 11:19 AM
  2. wms3's Avatar
    Incorrect. I have used any number of different USB cables, data cables, Chargers, etcetera with both a Samsung Galaxy Tab 7 inch, samsung galaxy s3 phone, and now a Samsung Galaxy Tab 8.4 Pro
    Posted via my Samsung Apple killer
    03-14-2014 02:30 PM
  3. mattskr's Avatar
    I haven't had any problems either using any USB cable with either the Tab Pro or S4
    03-14-2014 03:56 PM
  4. Dualmonitors's Avatar
    Thanks folks. This is really strange...
    Well, for one, my TabPro 8.4's charger's output is 5.3V and the Note 8's charger's output is 5.0V.
    But...back to the USB cables: I was specifically warned, in another forum (don't recall which one), that some folks had issues with their S3s by using non-Samsung original USB cables as 2 internal wires have been inverted in the S3's cables. That followed with the S4 as well. This is why I'm asking here regarding the TabPro 8.4 before I attempt to use the longer cable that came with my Note 8.
    Wonder why they include such incredibly short USB cables? Cost? Ugh.
    03-14-2014 05:13 PM
  5. wms3's Avatar
    I connected my Tab Pro to my comp with a 6 ft USB cable from Amazon no issue
    Posted via my Samsung Galaxy iPhone killer
    03-16-2014 04:17 PM
  1. Wifi problems Samsung galaxy s4 mini
    By Vivianejim in forum Samsung Galaxy S4 Mini
    Last Post: 11-15-2014, 05:33 AM
  2. Rooted Samsung Galaxy S4 Trouble Please Help
    By Justin Kenney2 in forum Introductions
    Last Post: 03-31-2014, 04:31 PM
  3. Verizon Note 2: Rooting question
    By jpriest007 in forum Verizon Galaxy Note 2
    Last Post: 03-15-2014, 05:39 PM
  4. Cyanogenmod 11 Memory problem on Samsung galaxy s3
    By DrewBeezy in forum AT&T Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 03-14-2014, 01:22 PM
  5. Quick Comparison? G vs X
    By Unicorn Rancher in forum Moto G (2013)
    Last Post: 03-14-2014, 12:28 PM
