1. Mr Zed's Avatar
    Hi guys, I bought this tablet after falling in love with the display when trying out a display unit at a store. Unfortunately, my Tab Pro 8.4 has this issue where if you press only slightly on the display near the bezel on the left side roghly near the micro SD slot, it would squeak and make a creaking sound quite loudly like the LCD is not quite well put together, and I noticed this after just a few hours of use. After getting a replacement unit around 2 weeks after sending it for repair, it is suffering from the same problrm amd only after a few hours of use as well. Not only that, my micro sim card is stuck inside the micro sim slot... (I have the LTE version)
    Is anyone havimg similar build quality issues? Anyway this is probably going to be my first and last Samsung device unfortunately. Totally unacceptable and annoying for a high end device to have this kind of issues.
    04-24-2014 04:47 AM
  2. mattskr's Avatar
    The first one I bought from Best Buy on the day they came out had an issue where the back would "click" when touched. Swapped it out and all is good.
    04-24-2014 06:06 PM
  3. Motorcop30's Avatar
    Maybe just the LTE version? I just bought one yesterday, wifi only though, but it's solid as a rock. Maybe you could swap it if still under warranty? I know the tab is pretty new, and it seems the first few batches sometimes have flaws until they get ironed out. Good luck!
    Sent from my SM-T320 using AC Forums mobile app
    04-26-2014 11:25 PM
  4. Mr Zed's Avatar
    Thanks for the replies. Like i said i am on my replacememt unit and it has the same creaking issue, and I also get sim card stuck issue as an unwanted bonus :-/
    My relative who pirchased the 16GB wifi only model is experiencing creaks on both his left and right side of body.
    My advise to those thinking of purchasing one is to be aware of the body, cause it is not a cheap tablet and yet you may be purchasing a tablet with a cheap build quality. Great screen though...
    04-27-2014 02:38 AM
  5. dgauvreau's Avatar
    Mine has seemed very solid so far (16GB Wifi) - build quality at least as good as my Nexus 7, and better than my Asus TF101
    04-29-2014 03:22 PM
  6. Channan's Avatar
    My old Nexus 7 used to always squeak when I squeezed the bezel just a little. Super annoying. I just tried squeezing the entire bezel all the way around my Galaxy Tab Pro 8.4 and not a single squeak.
    I have the 16GB Wi-Fi model, though.
    05-02-2014 12:10 PM
  7. storino03's Avatar
    I haven't noticed any faults in build quality, though I've had mine in a case since day 1.
    05-02-2014 07:27 PM
  8. Yowdroid's Avatar
    Mine feels very sold. The only negative is that the back cover is a bit slippery which makes it harder to hold.
    Sent from my Nexus 5 using Tapatalk
    05-03-2014 09:59 AM
  1. Galaxy S3 Random Battery Drain Issue.
    By Wetzel267 in forum AT&T Galaxy S III
    Last Post: 05-28-2014, 07:47 PM
  2. Question about noted email syncing issues
    By Poseign in forum HTC One M8
    Last Post: 05-04-2014, 10:00 AM
  3. Lock screen issue
    By Gregorich in forum Samsung Galaxy S3
    Last Post: 04-25-2014, 01:03 AM
  4. Reduced Quality When Recieving Multiple Photos
    By oman42 in forum HTC One M7
    Last Post: 04-23-2014, 07:25 PM
  5. HELP! Calendar Issues with changing repeat events.
    By LGPhoneIssue in forum Verizon LG G2
    Last Post: 04-23-2014, 05:08 PM
