Results 1 to 8 of 8
    Default while the fonts so small on this tablet?
    I tried changing to viewing on the web, expanding with my fingers but nothing helps. it seems like there are 12 year olds designing things at Samsung because the fonts at so small you need to be at least eight or ten years old to see them it doesn't make sense they have so much money they should just pay you the licensing fees to HTC because you don't have to do this on an HTC device course we can HTC can't make tablets either. oddly enough I really like this tablet. good luck editing with it also! I'm struggling with the stock browser or any tablet application same problem.
  2. #2
    Default Re: while the fonts so small on this tablet?
    You should be able to change font size by going to Settings>Display>Font size. If you're using Chrome, you can also go to its settings by tapping the menu button (while in Chrome), then Settings, then Accessibility, then adjust the Text Scaling to your preference.
  3. #3
    Has to do with screen resolution more than anything else. Certain apps are not compatible with the resolution of this (and other) tablets, so either the text is super small, or really big to scale to the screen.
    I found some relief in settings, device, accessibility magnification gestures. When you turn it on you an zoom in by "triple tapping". It's not like HTC'S phones where the fonts adjust AUTOMATICALLY to fit the screen size but it helps. You do have the option to turn it on or off, depending on the AGE OF YOUR EYES, thank you very much (end snarkyness).
  5. #5
    You could also try the app iFont. It gives a bunch of different app choices, so you should be able to find one that fits your liking especially after you change the font size to its maximum.
  6. #6
    jomarr's Avatar
    Posts
    Global Posts
    624 Global Posts
    Screen resolution.
    There's an option to make them bigger.
  7. #7
    The solution you offer does not work on the 8.4" tablet.
    I noticed that there is scaling on the 10" tablet and that is on the Settings>Applications menu.
    There is no scaling on the 8.4" tablet that I could see following your directions.
  8. #8
    This does not change the application font sizes. It only changes the Samsung labels.
  1. So now that the S5 Lifeproof is out
    By fofjjsr in forum Samsung Galaxy S5 Accessories
    Last Post: 07-24-2014, 01:24 PM
  2. Meaningful Android 4.4.3 improvement on M8 GPE.
    By EWY in forum Google Play edition HTC One M8
    Last Post: 06-09-2014, 01:02 AM
  3. Replies: 0
    Last Post: 06-08-2014, 11:22 PM
  4. notifications on icons
    By Gallion in forum Samsung Galaxy S5
    Last Post: 06-08-2014, 09:43 PM
