04-01-2016 10:07 PM
54 123
tools
  1. jdillworth's Avatar
    This is my first Android tablet, I really like it.
    Trouble is, it sometimes seems to stall in its charging. It's particularly noticeable when I wake up in the morning and its' been charging all night and its not 100%
    Tried watching it tonight:
    9:38pm started charge at 58%
    9:44pm 61%
    9:57pm 65%
    10:26pm 69%
    10:36pm 69%
    10:55pm 69%
    11:28pm 69%
    (reboot device, unplug adapter, plugin again)
    11:31pm 68%
    11:56pm 75%
    12:07am 100%
    This end result makes me wonder if the battery percentage is simply wrong, but if that's the only problem, why doesn't it charge overnight?
    Any advice would be much appreciated
    06-14-2014 11:37 PM
  2. jdillworth's Avatar
    Last night I powered down the tablet with about 97% charge, I powered on this morning and it was 74%. I'm wondering if the percentage is just off?
    06-15-2014 12:59 PM
  3. storino03's Avatar
    Why do you power it down when you go to sleep? I leave it plugged into the charger and haven't had any charging issues whatsoever.
    06-15-2014 01:26 PM
  4. jdillworth's Avatar
    It's because I'm suspecting a software issue is at the root of it. I've left it powered-on charging overnight a couple of times (and not excessively drained, still 50% power or so) and I woke up to high 80s or low 90s percent.
    06-15-2014 02:15 PM
  5. storino03's Avatar
    Full reformat?
    06-15-2014 05:49 PM
  6. jdillworth's Avatar
    Full reformat?
    I'd like to save that for a last resort... I'm hoping someone has another idea.
    I just successfully charged to 100% while powered on and with no special treatment.
    I hate this kind of issue. If it doesn't do it all the time, how do I know when it's fixed?
    06-15-2014 07:16 PM
  7. storino03's Avatar
    Try using the official white power brick and usb cable. Maybe try another power outlet. That particular one could be providing less power or plugged into a power strip.
    06-15-2014 09:53 PM
  8. jomarr's Avatar
    I had problems with mine as well. From 56% to 54% overnight and that's with the charger on. Tried charging it until lunch time and it didn't move. It's fine now. Probably a software issue
    06-15-2014 10:30 PM
  9. jdillworth's Avatar
    Glad to hear it didn't turn into a major problem. Assuming it's software, hopefully an update will resolve it 100%.
    Thanks!
    06-15-2014 11:24 PM
  10. jdillworth's Avatar
    That's an interesting thought. I have been using the official brick, but with a surge strip and an extension cord (makes it easy to have on my desk while charging).
    I'll plug in elsewhere and see if that changes anything.
    06-15-2014 11:26 PM
  11. jdillworth's Avatar
    OK, this time no extension cord, different surge protector, different outlet. I put it on the charger last night at 51% and woke up to 86%.
    06-16-2014 09:12 AM
  12. Civuck's Avatar
    Similar issue here. Battery remaining value was fine for first month or two. Now it is stalling occasionally during recharges. I don't believe it is power adapter related. My feeling it is a software bug in the reporting.
    06-16-2014 10:58 PM
  13. storino03's Avatar
    Yeah, I JUST now experienced this. It definitely is with the newest update ND3 that came out recently.
    Annoying to say the least!
    06-17-2014 05:34 AM
  14. Civuck's Avatar
    I'm still on original firmware from February and have this stalling charge problem.
    06-17-2014 08:11 AM
  15. storino03's Avatar
    Then it's either a software update that we all have shared, whether it's through Samsung Hub, Google Play, or otherwise, is what's causing the problem.
    06-17-2014 03:00 PM
  16. storino03's Avatar
    06-17-2014 03:02 PM
  17. cgr45's Avatar
    I'm having the same issue. The only way it will fully charge is by been off while plugged in.
    06-17-2014 10:15 PM
  18. jdillworth's Avatar
    I'm pretty sure I tried that and it didn't work in my case.
    I've contacted Samsung. After checking what apps were using the most battery (Screen and Android System in my case), their response was to try a factory reset. So I've taken the original advise of storino03.
    Lost my GT Racing 2 progress
    Anyway first night it charged fully, but I was only down to 60-something.
    It's plugged in now, charging from 20% and has hit 83%. Hopefully it will go all the way up.
    06-17-2014 11:20 PM
  19. jdillworth's Avatar
    No good, it stopped at 94% and stayed there for at least 7 hours. Unplug and plug in again and now it's topping off.
    So the factory reset didn't solve it.
    06-18-2014 09:54 AM
  20. jdillworth's Avatar
    I just talked to a tech at Samsung. When I said I had done a factory reset, he asked how.
    After explaining I had used the settings app, he had me reset an alternate way. Now I'm going to see if I can charge normally.
    Here's the alternate way if it's useful:
    Press and hold: Volume Up + Home + Power
    (They have to be depressed in that order)
    You'll then go into a menu system that can be used to do a factory reset.
    06-18-2014 10:54 AM
  21. cgr45's Avatar
    This is exactly what happens to me. Gets to 95% and it stops. I have to turn it of for it to fully charge. When I turn it on and start using it it goes from 100% to 90% in 5 minutes. I should had kept the LG GPad
    06-18-2014 12:21 PM
  22. jdillworth's Avatar
    Just hit 100%!
    This is my first attempt after contacting Samsung and learning of the key combo reset (Press and hold: Volume Up + Home + Power (in that order)).
    If I can hit 100% 3 days in a row, I'm calling it fixed.
    ... I should had kept the LG GPad
    Like others, I think this is likely software. No one gets software right, so while I'm very frustrated I have to cut them some slack. Samsung released a herd of new tablets this year so far. It can't be easy to get everything right.
    LG G pad was in the running when I bought the Galaxy. I don't know why LG released almost the same time as Samsung but with the previous generation Snapdragon (maybe they just missed some timing window?). For the record I liked the G Pad software and design better. Just couldn't ignore the specs and price.
    06-18-2014 10:54 PM
  23. laestrella's Avatar
    I'm having the exact same issue except my tablet after a while will get to 100% (if i constantly unplug and plug it in) but then after a few minutes after being on will suddenly drop 10-40%. Or the percentage will drop at some random time during the day.
    This is frustrating and I just want to throw it back at Samsung.
    06-20-2014 12:22 AM
  24. storino03's Avatar
    I drained my battery down to 10% as what was suggested in the other link I posted, and charged it all the way up to 100% and now my device is reporting the correct battery percentage. I think there's a bug with the way Samsung's software is reporting the correct "full" battery timings.
    It hasn't happened since and charging it every night, brings it back up to 100%.
    06-20-2014 03:22 PM
  25. gman16000's Avatar
    "(Press and hold: Volume Up + Home + Power (in that order))."
    Thank you!! I tried everything. This worked!!! And it did not blow away anything on my tablet.
    06-21-2014 10:55 AM
54 123
  1. Samsung default Internet browser
    Last Post: 07-09-2014, 12:58 PM
  2. Using a USB WEBCAM With Tab-2
    By extraclass in forum Samsung Galaxy Tab 2
    Last Post: 07-09-2014, 08:46 AM
  3. Galaxy Note 2 Battery charges very faster and drains fast
    By hitinder in forum Ask a Question
    Last Post: 06-29-2014, 09:19 PM
  4. Samsung S2 phone question
    Last Post: 06-15-2014, 02:10 AM
  5. change home buttons on samsung s2
    Last Post: 06-15-2014, 01:35 AM
