I have an S2 tablet. I can't get the door open to insert a SD card. Help! What could the problem be?
  • Start date Start date
A
AC Question
There is a little hole at one end of the door but it won't budge.
I'm having the same problem. The micro sd slot does not pop out when the metal pin is inserted and pushed lightly into the tiny hole. I was able to open the aim card slot. Any suggestions on how to fix this?
Have u found an answer? I have this same enjoying problem:(
Are you all using the tool that came with the tablet? If not, make sure whatever you're using is thin enough to enter the pinhole fully. Paper clips are often too thick.
I don't have this device, but in my experience with other devices with this kind of SD or SIM tray, you often have to apply a decent amount of pressure in the pinhole to eject the tray. Push a little harder.
push the pin in really hard, until it sort of clicks. The card carrier will then pop out. Remove it totally, insert the card in the holder, then return to slot and push it in.
Thanks guys. I had to push really hard. I was afraid of breaking something, but it finally popped open.
ecomranx07
