Results 1 to 16 of 16
    Default Turn off tap sound when typing? Driving me nuts!
    Can anyone tell me if there is a way to turn off the sound the keypad makes everytime you type a letter? Like the little click sound? When using swype it doesnt make a sound but when not using swype it does and its driving me nuts! Thanks.
    Melissa
    Melissa
    Cingular Razr > TMobile Blackberry Curve 8300 > Sprint Palm Centro > Sprint Blackberry Curve 8320 > Sprint Blackberry Curve 8530 > Sprint Palm Pre *SEMI-WIN*> Verizon Pixi Plus *MEGA FAIL*> Verizon Droid X2 & Samsung Galazy Tab *WIN*
  2. #2
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,226 Global Posts
    ROM
    NOS M7 Sense 5.0
    Default
    Pull down you notification bar and hit the silent setting. Or you can try another keyboard like swift. I agree the sound is very annoying.
    Sent from my ADR6300 using Tapatalk
  3. #3
    Default
    I'm not sure what the settings are in your phone, but some have an option to turn that off in the keyboard settings.
    Beamed down to the earthlings from my eVo
    ......posted from something made by Apple!
  4. #4
    armdavid2's Avatar
    Posts
    Global Posts
    110 Global Posts
    ROM
    miui/cm7 stock
    Default
    go to sound settings, vibration intensity....adjust there.
    Same place on all 2.2 phones/tablets. same problem with evo....was wicked loud
    Curve 8310 >>Palm 800w >>Touch Pro >>Evo 4G>>Evo 3D
    >>Galaxy tab>>Acer A500
    Default
    I installed Swift and its great. Taking a little adjusting to the keys but at least the sound is gone!
    Melissa
  6. #6
    Default turning off key click-Samsung Fasinate
    This has been driving me crazy and after seeing this thread I did figure it out. I would only assume it's the same for most android phones.
    Go to settings, language & keyboard, android keyboard and make sure sound on keypress is unchecked.
    Thanked by:
  7. #7
    prezmater's Avatar
    Posts
    ROM
    Stock
    Default
    Quote Originally Posted by sybrants5505 View Post
    But alas the SGT uses a Samsung Keyboard and not the Android Keyboard. It also has Swype pre-installed, but I find it awkward to use on my Tab, but you could try it.
    I personally installed GingerKeyboard on my Tab, same with both of my EVOs and my buddies Eris. So much better (IMO).
  8. #8
    Default Re: Turn off tap sound when typing? Driving me nuts!
    Like prezmater I just installed a different keyboard and turned the sound off in its preference, I like the , it's clean and has quite a few customization options.
  9. #9
    Just turn the "System Volume" down to nothing. Basically, just do this when your SGT is on it's home screen. Hit the volume down arrow on the side, and the keypad clicking will go away.
  10. #10
    Hello, I've have the solution! I just this phone yesterday and that noise had to go!
    Here is what you do (tested only on htc evo 3d):
    Go to settings
    Then sounds
    Turn audible touchtones off
    The keyboard still vibrates but the clicking sound is enabled. Happy typing!
  11. #11
    Smile Re: Turn off tap sound when typing? Driving me nuts!
    Thank you so much - I'd tried all sorts of things before discovering I needed to go to language & keyboard rather than sound settings.
  12. #12
    check your swype settings too
  13. #13
    Go Setting>Language and Input>the click the gear next to samsung keyboard>advanced> then uncheck the tey tap vibrations and key tap sound. Hope this helps
  14. #14
    I am the odd woman out here, I want the sound...I figured out how to turn it on but I can barely hear it, turned up all my sound settings I could find and its still barely making any sound..how can I turn it up?
  15. #15
    Evar4life's Avatar
    Posts
    Global Posts
    2 Global Posts
    That worked for my Samsung Galaxy Note II. Thanks!!!
    Settings - Language and Input - Samsung Keyboard (Click on the Gear Next to it on the right hand) - Advanced - Key-tap sound Uncheck.
  16. #16
    This worked for me (S3) thank you! That sound was driving me nuts
