1. kbo911's Avatar
    Hi all, sorry if this is posted somewhere else. I have 2 questions.
    First question is "how is the battery life of the phone when paired with a smart watch? I'm not sure if different brands of watches matter." I have a note3 running kit kat
    Second question "what is the range of the blue tooth, that is, can you have the phone downstairs and be upstairs and will the watches functions still work?"
    Thanks
    Sent from my SM-N900W8 using AC Forums mobile app
    04-12-2014 09:26 AM
  2. Jnorton2724's Avatar
    The range of the gear 2 is pretty far from what I've noticed. Battery life doesn't seem horrible with it connected all the time. I don't use the stock battery but it doesn't seem to be draining dramatically more battery.
    kbo911 likes this.
    04-12-2014 01:36 PM
  3. ironsoulreaver's Avatar
    I noticed a small increase on my phones battery usage. The watch can go a decent distance depending on whats in the way. I've lost connection with the watch while the phone was in my pocket.
    04-13-2014 02:14 AM
  1. Galaxy S5 battery issues already?
    By philliplavelle in forum Samsung Galaxy S5
    Last Post: 08-27-2014, 07:55 PM
  2. Would you recommend this phone?
    By Karen667 in forum Sony Xperia Z1 Compact
    Last Post: 07-21-2014, 09:17 PM
  3. Battery Problems
    By li33gwm in forum Samsung Galaxy S5
    Last Post: 04-12-2014, 09:51 AM
  4. Replies: 0
    Last Post: 04-12-2014, 05:05 AM
