1. Civuck's Avatar
    The Gear 2 is my first experience with a sleep monitor.
    How exactly, in technical terms, does it work?
    And how can the sleep monitor provide unique observations on your particular sleeping behavior when a lot of people don't sleep alone?
    04-14-2014 01:15 AM
  2. Kelly Burby's Avatar
    @Civuck There is nothing magic in sleep monitor, It is just based on the noise intensity lesser the noise good will the sleep results, it detects the noise you are making while you are sleeping like when you've had a good sleep then you will not snor or change position frequently this means that no noise would be there, sleep monitor application can't working in the place which is very much noisy and as far as the unique results are concerned they are not accurate it works on the approximation.
    04-14-2014 06:15 AM
  1. heart rate monitor horribly inaccurate?
    By grabaka in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 10-14-2016, 08:51 PM
  2. Moto Assist Sleep
    By benhaube in forum Moto X (2013)
    Last Post: 04-20-2014, 10:59 AM
  3. Replies: 8
    Last Post: 04-12-2014, 02:04 PM
  4. Moto X: Assist Sleeping
    By shadolyn in forum Moto X (2013)
    Last Post: 04-12-2014, 06:42 AM
  5. Network disconnect on screen sleep
    By NJD_fan in forum Droid RAZR MAXX
    Last Post: 04-10-2014, 02:16 AM
