1. sashapave's Avatar
    I couldn't figure out why my Note3 wasn't installing any apps until this: A great post in the Verizon Note3 forum:
    I picked up the Gear 2 yesterday and I'm loving it so far, the only problem I have had was installing apps through the Samsung Apps link in Gear Manager. It was wrecking my brains all day, but I figured it out.... I reinstalled Samsung Apps through this link Samsung Apps (Pick the one for phones. Don't do the tablet one!) After that, no problems other than the barren appstore.
    I hope this helps someone, if not at least it helped me. Be blessed.
    04-14-2014 11:13 AM
  2. Sureshot3087's Avatar
    I was having the same problem. THANK YOU!
    04-19-2014 01:20 PM
  3. jj423's Avatar
    still doesn't work for me..."failed to install app"...
    04-25-2014 01:47 PM
  4. Batman8888's Avatar
    I was having the exact same problem with my Gear 2 where I couldn't install ANY apps no matter what! I tried the optional link above in this post to the Samsung Apps but with no luck at all. Then, out of frustration I did a Factory Data Reset on my Note 3, as well as on my Gear 2 (which still didn't solve the problem), but THEN I installed the Samsung Apps from the link above, and that did the trick. Not only am I able to install apps now on my Gear 2, but the reset also helped with the connection back and forth between my Gear 1 and Gear 2. It appears that these devices prefer a "clean install" which helps them work much better, especially if you already had the Gear 1 and all it's software already installed.
    After having the Gear 2 for two weeks now, I am finally able to do something with it. Before this, I could not get ANY notifications at all or install any apps, along with a few other problems which made my Gear 2 almost useless, so I had to try something. I spoke to Samsung tech support almost daily but they could never resolve the problems.
    If all else is failing, try it.
    04-25-2014 04:54 PM
  5. JacksonEdwardHarrison's Avatar
    Awesome news man! Congrats!
    04-25-2014 05:01 PM
  1. Recommend Bluetooth Headphones for use with Gear 2
    By Civuck in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 12-25-2016, 09:37 PM
  2. Call and Text Messaging apps color themes
    By mojaxson in forum Samsung Galaxy S5
    Last Post: 03-01-2016, 05:45 PM
  3. HTC One (M8) No FitBit App on T-Mobile?
    By cizzlen in forum HTC One M8
    Last Post: 04-14-2014, 12:47 PM
  4. [Free] My homemade APP - Make a wish
    By Kenneith Lin in forum Android Apps
    Last Post: 04-14-2014, 10:37 AM
  5. Need help with kindle fire root, stuck on daemon started successfully
    By FailAtEverything in forum Amazon Kindle Fire HD
    Last Post: 04-14-2014, 09:53 AM
